Reflex wipers on an 05 Accord?
Old Jun 22, 2005 | 01:43 PM
skipper
Guest
Posts: n/a
Has anybody tried those "Reflex" wipers sold at Canadian Tire on an 05
Accord? My Accord comes with a 26" and 18" wipers but the Reflex wipers go
to a max of 24". Would that still work?
Thank you
Pars
Guest
Posts: n/a
Re: Reflex wipers on an 05 Accord?
I got em installed on my 98 Civic last week for the first time. I've got
high hopes for them. If they can last the summer without streaking, I'm
going to be hooked. My current Bosch blades didn't last long enough to
justify the expense, hopefully the Relfex blades will do better.
Blades as shown:
http://www.canadiantire.ca/assortments/product_detail.jsp;jsessionid=C1mR1H1ow6AwYTAsCZbR ZZ2Ge0PfYOFvQvhlOTF81KYi2E2Zk9yt!2141247753!172915 568!7205!7305?PRODUCT%3C%3Eprd_id=845524443278593& FOLDER%3C%3Efolder_id=2534374303517476&bmUID=11192 17297504
A smaller size wiper blade might work (larger size is not going to work,
since it'll extend beyond the windshield). It the off-spec blade can still
capture the water from it's smaller sibling and you're physically short
enough not to be hampered by the diminished coverage, it should be ok.
Pars
"skipper" <bluejays_99@sympatico.ca> wrote in message
news:rGhte.30962$Kk4.44838@news20.bellglobal.com.. .
go
> Thank you
S.S.
Guest
Posts: n/a
I had Bosch Micro-Edge blades on my '93 Accord last year, and they didn't
work well at all. So this year, I got a set of OEM blades from the local
Honda dealer for about the same price as the Bosch blades. So far, the OEM
blades are the best blades I've ever had on the car.
Pars
Guest
Posts: n/a
OEM
The wife uses the OEM blades on 2000 Civic (but she only gets the refill for
about $5...which is a reason to keep the stock wiper blades...otherwise, you
can't use the Honda refills). Anyways, the OEM refills seems to be a little
better then the regular junk, but not better then the Bosch. I initially
started using the Bosch blades couple years back and they were excellent,
but the last pair I used were garbage. They started streaking only after
couple month of use.
Pars
TaubBaer
Apr 20, 2015 06:25 AM
shawnshank
Oct 19, 2013 04:45 AM
Rod2Rice
May 22, 2008 07:09 PM
Stan
Jun 3, 2005 01:06 AM
Howard Lester
May 4, 2005 11:16 AM
