Vibrating Honda
Old Jun 22, 2005 | 01:43 PM
femolar
Guest
Posts: n/a
Vibrating Honda
my 2002 honda accord se vibrates strongly when i brake at a full speed but
does not if at a lower speed. i tried getting it check but no result yet,
pls what could be wrong with it
butch burton
Guest
Posts: n/a
Re: Vibrating Honda
warped front brake rotors - did you have the tires rotated or removed
recently - generally it is the boys with the impact wrenches - you
might be able to reduce the shimmy by retorquing the lug nuts.
A word about tightening lug nuts - if you tighten lug nut #1 to 80 FP
or whatever your manual sez - much less for fancy rims - and then
tighten #2 thru 4 lugs to 80 FP - #1 is probably way tight cause the
wheel was not centered till the other 3 lug nuts were tightened.
Partially tighten them all and then go to the required FP (Foot Pounds
of torque).
I never let anyone with a impact wrench even get close to my lug nuts -
even if they have torque sticks. Rotors are fairly easy to replace on
the later accords. A DIY job.
Frank
Guest
Posts: n/a
Re: Vibrating Honda
brakes or ball joints getting weak. The wheel alignment could also cause
vibration a high speed but that happen even when not braking.
"femolar" <fkfemi@hotmail.com> wrote in message
news:aa2c71038663d6241790663d457e967e@localhost.ta lkaboutautos.com...
cocococo1
Guest
Posts: n/a
Re: Vibrating Honda
Hi, I have just had an almost identical problem on my Prelude vtec.I had a
severe wheel wobble at high end braking and the car would judder felt like
it would fall apart.
I tied to emove the pads to check fo any run out on the disc's and it was
then I found that the caliper was not releasing when I stopped braking
causing a slight braking effect all the time and overheating so that when
you did brake the disc was distorting where the two plates ae joined.
Stripped the caliper down and cleaned both piston and inner surfaces
rebuilt, had to have disc refaced but perfect now. Hope this helps.Vic
cocococo1
Guest
Posts: n/a
Re: Vibrating Honda
Sorry about the missing R's dodgy laptop keyboard
R. P.
Guest
Posts: n/a
Re: Vibrating Honda
Well, if all else fails, you could at least look at your car as an
oversized sex toy.
R. P.
jim beam
Guest
Posts: n/a
Re: Vibrating Honda
re-torque the front wheels. sequence is 1324, for 4 lugs or 13524 for
5. do half tight first, then full tight. do /not/ use an impact wrench.
Zardiw
May 17, 2019 05:41 PM
CommanderSlug
Jan 11, 2017 08:27 AM
Press Fit
Dec 19, 2016 10:50 AM
Spyderfenix
Jan 22, 2010 04:04 PM
bertbarndoor
May 4, 2005 04:44 PM
