Honda prelude vtec main relay
Old Jun 23, 2005 | 11:43 PM
cocococo1
Guest
Posts: n/a
I have had advice on te testing of the main relay and all seems well but I
assume fuses cover the supply to this unit and does any one have any idea
which fuses they are and where do I find them as all writing is in
Japanese its hard to tell one from another without looking for all fuses
and checking each one in turn.
Thanks
Vic
TeGGeR®
Guest
Posts: n/a
Re: Honda prelude vtec main relay
"cocococo1" <mtubbies@btinternet.com> wrote in
news:63d9fca8e854ba1a172d5ebd906bdfca@localhost.ta lkaboutautos.com:
> but I assume fuses cover the supply to this unit and does any one have
> any idea which fuses they are and where do I find them as all writing
> is in Japanese its hard to tell one from another without looking for
> all fuses and checking each one in turn.
There are three fuses.
http://www.tegger.com/hondafaq/mainr...ion/index.html
If you can't find the fuses (I don't know Japanese either...), you can
still check for voltage at the appropriate pins in the Main Relay connector
with the ignition on. Those are all the same between models.
If you've managed to achieve the not-inconsequential task of replacing your
head gasket, you should be able to work backwards from the diagrams
referenced above.
Good luck.
TeGGeR®
Panthese
33
Aug 18, 2020 12:08 PM
seth8288
Jun 27, 2017 07:14 AM
savemyjazz
Mar 19, 2015 11:08 PM
egvtec
Jan 20, 2013 11:12 AM
flipbego17ia
May 4, 2005 11:16 AM
