Does a radiator cap do anything?
Old Feb 19, 2008 | 09:22 PM
pastafarian's Avatar
Other than aesthetically?
Old Feb 19, 2008 | 11:24 PM
Kelmar's Avatar
Frequent FitFreak Poster
well, it keeps the fluid in the radiator but that's about it.
Old Feb 19, 2008 | 11:27 PM
solbrothers's Avatar
iirc there's something about pressure. you can get different PSI ones that'll fail at different pressures.
Old Feb 20, 2008 | 01:14 AM
dank24's Avatar
Raises the boiling point
Old Mar 3, 2008 | 08:29 PM
The BOM's Avatar
Different caps have different pressures at which they discharge coolant into the reservoir. A higher pressure means it also raises the pressure exerted on the coolant thus raising it's boiling point. A different cap may improve the cooling efficiency in hard driving conditions but it will demand more from hoses, thermostat, and other components. This also may put more pressure on your stock head gasket where the water channels meet. This may be a serious issue, but i havn't expiramented... so i only have logic and science to back it up
My advice: keep your stock one unless you hit the track with your heavily modded Fit
Old Mar 3, 2008 | 09:01 PM
Oh im not planning on racing my fit or anything, i was just wondering, bec I see a lot of radiator caps and stuff online, and i saw this video on drifting and the guy said that a different shift knob and radiator cap are some basic upgrades for drifters, so i says to myself, "A shift knob makes sense, bec shifting is important in all facets of racing, but how can a radiator cap help you go sideways" laff
Jeff Pirkey
Feb 5, 2012 11:06 AM
HondaFitted2007
Oct 9, 2008 01:18 AM
chuck
Oct 19, 2005 02:39 PM
Krystyne
Sep 30, 2005 04:36 PM
spacetrax@wi.rr.com
May 18, 2005 11:20 PM
