How to fix a nitrogen oxide problem?
Old Jun 28, 2005 | 11:34 PM
isabelaneric
Guest
Posts: n/a
My 95 Honda Accord got an emissions testing & the Nitrogen Oxide levels
were to high? How can I fix it cheap?
Old Jun 29, 2005 | 01:56 AM
motsco_ _
Guest
Posts: n/a
Re: How to fix a nitrogen oxide problem?
Better details yield better answers.
What state / province, what have you tried so far, what's the MILEAGE,
what kind of gas do you use, has the car been serviced in any way,
lately, anything unusual happening with the way it runs otherwise, was
the car warmed up properly before the test, have you ever put fuel
injector cleaner in the fuel, is radiator reservoir full according to
the manual, ??????? Good start.
'Curly'
Old Jun 29, 2005 | 10:39 AM
TeGGeR®
Guest
Posts: n/a
"isabelaneric" <isabelaneric@yahoo.com> wrote in
news:c8d3d3c143e3521dd923f18517e0b3f2@localhost.ta lkaboutautos.com:
We need to see your numbers. Need your readings plus the limits in your
jurisdiction.
Also need what Curly is asking for in the other reply.
High NO is the product of excess combustion temperatures and/or a lean
mixture. Plugged EGR passages, a partially non-functional EGR valve, a
small exhaust leak ahead of the cat, excessively advanced ignition timing,
all these can cause high NO.
TeGGeR®
www.tegger.com/hondafaq/
andrew416
May 21, 2008 06:52 PM
Spoilaz via CarKB.com
Aug 9, 2005 10:30 PM
sonal83
Jul 27, 2005 10:30 AM
edmacatack
May 4, 2005 11:16 AM
classicred
