Trying to find right tire size
Old Mar 8, 2008 | 03:16 PM
MNfit's Avatar
I got some rims for my car 16X7 +42 offset and I'm trying to find the right tires size for the rims. as of right now the ride height is stock but I hope to lower it on Progress springs I was looking at 205/40/16 do you think that would be a good size? Also would a 195 be stretching the tire?
Old Mar 8, 2008 | 05:11 PM
mimpi's Avatar
I would run 195/50/16 or 205/45/16, the 40 profile makes the look of the wheel tiny. those two size will get you the same rolling diameter as the stock. 195 on a 7" i wouldnt say it stretches.
Old Mar 8, 2008 | 05:56 PM
sosoqtpinoy's Avatar
205/40/16...
Old Mar 8, 2008 | 06:35 PM
JDMchris.com's Avatar
I run THIS
205/45/16 is what I always run
Old Mar 8, 2008 | 06:52 PM
chaseerry's Avatar
Same here.
Old Mar 9, 2008 | 08:42 AM
mmmkelley's Avatar
I have a set of 16x7 wheels with an offset of 40mm and plan on running 205/45/16. Will I have any rubbing running on the stock suspension?
Old Mar 9, 2008 | 12:08 PM
chaseerry's Avatar
No. I ran that exact setup for a while before dropping, and never once rubbed. Even on hard corners and such.
Old Mar 9, 2008 | 02:28 PM
MNfit's Avatar
so you guys dont think I will be rubbing with a 45 series tire? Looking threw the Tire set up thread I thought I saw some one running a 16X7 with a 45 and said there was some rubbing. I dont remember if his car was lowered or not. Is there really that big of a difference between a 40 and 45, I wouldn't think there is.
Old Mar 9, 2008 | 04:33 PM
mmmkelley's Avatar
Thanks for the quick reply. I'm getting the wheels powder coated this week and wanted to know which tire size wouldn't rub.
Old Mar 14, 2008 | 04:32 PM
mahout's Avatar
205/40x16 will be about 1" smaller than 195/55x15 so the 'gap' will increase by half-inch. 205/45x16 will be better, about .2" smaller.
205/40x17's are close to stock diameter. And they will work on 17x7 wheels with 42 mm offset unless you have lowered.
Nio4
Jul 2, 2013 10:45 PM
Theos92vr4
Mar 12, 2012 01:32 AM
R..F..G
Dec 13, 2011 10:23 AM
AtticusFit
Jun 21, 2008 12:55 AM
hiphapa
Jan 23, 2008 10:44 PM
