Which tire size is better for me? 205/45/16 or 205/40/16 help me!
Old Mar 5, 2012 | 09:18 PM
Theos92vr4's Avatar
Hey guys. I plan on getting new wheels for my fit. 16x7 Drag DR31 40 offset (link below) I am lowering the car on Tanabe DF210 springs (1.3 drop and 1.8 rear)
I am wondering which tire size will be better for me. 205/45/16 or 205/40/16? I dont want the car to rub, or if it does very slightly. Should i be fine with the 205/45 or should I go 205/40
Heres the link to the wheels. Thanks guys!
Wheel Details - Discount Tire Direct
Old Mar 8, 2012 | 08:45 PM
slp950's Avatar
I would go with the 205/45-16. It's closer to stock height overall, you will keep a slightly better ride due to a taller sidewall and your options are greater coupled with typically lower prices. As far as rubbing goes you shouldn't have any issues. I've run more agressive setups without any rubbing problems unless you run spacers in rear and carry a bunch of people in the back.
Old Mar 8, 2012 | 10:23 PM
Hootie's Avatar
^^ That would be true (tire size wise) if it were a GD chassis but in the case of the current GE the recommend tire size is 205/50R16.
As far as rubbing, GE's are much more sensitive to lower offsets with wider tires especially when lowered from what I've gathered from the various threads on here. There is a good chance you're tire would rub when lowered with the correct 20/50R16s mounted on wheels of your specified dimensions.
Old Mar 9, 2012 | 09:41 AM
slp950's Avatar
You are correct that a 205/45-16 is closer to the gd3 chassis is tire diameter and that a 205/50-16 is closer in diameter to the ge8 is tire. But since the op didn't ask what tire is the closest in diameter, I answered his original question as to which tire size was closer.
Honestly, I would run the 205/45-16 over the 205/50-16 for a few reasons. The overall height is only 0.75" approx, and the difference in speedometer reading is only 3.2% in regards to vehicle traveling slower than displayed, I.e. if speedo shows 65 you would be doing 63.8. Also you would have better clearance for aftermarket wheels in regards to width and offsets.
Old Mar 9, 2012 | 09:52 AM
Mr. Win's Avatar
Agreed, I also think it just looks better on the fit.
Old Mar 9, 2012 | 12:59 PM
hatchpat's Avatar
205/45 would be more appropriate for the roads up by us!
Dodging potholes some days is like a game of frogger, especially
On Rt. 46!!!!!!
Old Mar 9, 2012 | 04:49 PM
2__9fit's Avatar
just put on a set of Firehawk Wide Oval AS at 36kmiles 205/50/16 like em so far 50K tire Vrated
3 for 1 price
Old Mar 11, 2012 | 11:42 PM
Theos92vr4's Avatar
Thanks for all the responses guys! Wound up goin with 205/45/16 on the flat black drag dr31 wheels.
On Rt. 46!!!!!!
hahah wow you are right in allamuchy! Didnt know there were people on this forum this close to me. Ill give ya a honk if I see you around
Old Mar 12, 2012 | 01:32 AM
hatchpat's Avatar
Very cool. I will also do the same!!!
SikxChoi
SoCal Classifieds
Jan 30, 2014 01:52 PM
AtticusFit
Oct 11, 2012 10:16 AM
Santiad
Oct 23, 2011 09:01 PM
AtticusFit
Jun 21, 2008 12:55 AM
MNfit
Mar 14, 2008 04:32 PM
