using 13" winter tires??
Old Mar 12, 2008 | 02:51 PM
blackmtnside's Avatar
Hello everyone,
My new Fit will be here in a few days. It's pretty much the end of winter here now, so I'm planning to just run the tires that come with it for now, but for the next winter, I have a set of 175x70R13's that are practically brand new.
In terms of tire size, I used one of those tire calculators and found the difference in size is something on the order of 1.5%, which probably isn't much to worry about. However, I have no idea what the bolt pattern on the 14's are, and whether or not a 13 would even fit over the calipers/discs!
Anyone out there who might be able to offer any insight?
Old Mar 12, 2008 | 03:10 PM
CorrodesTheFilm's Avatar
I'm not sure whether or not a 13" wheel will fit over the brake calipers, but I can tell you that the Fit uses a 4x100mm bolt pattern for the wheels.
Good luck!
Old Mar 12, 2008 | 03:17 PM
john trials's Avatar
I am currently using snow tires/wheels from my old Civic on my Fit. They are Honda 14" steel rims. There is less than 1/4" clearance between the inner rim and the brake caliper. It is a VERY close fit. I thought I might have problems with road debris getting stuck between the caliper and rim, but it's worked well all winter.
There is no way a 13" rim will work.
Old Mar 12, 2008 | 03:24 PM
Darn. Thanks for the quick answer!
Guess I'll look for new winters on clearance.
stephenmarklay
Sep 19, 2018 02:26 PM
oveedrx
Jan 4, 2015 08:07 AM
Sabiokah
Apr 20, 2010 05:22 PM
brdss
Sep 27, 2008 01:08 PM
fit2bowner
Sep 22, 2008 11:42 AM
