Re: 88 civic SI burning oil at acceleration...
Old Jul 7, 2005 | 01:26 AM
TeGGeR®
Guest
Posts: n/a
Eric <1@1.com> wrote in news:o68pc11tp5tj07igi0ufjabr3d50p64n0f@4ax.com:
> but not always. It seems it may be somewhat weather dependant. When
> it's hot it's usually bad. Also, often it doesn't smoke at all. I've
> cleaned the PCV tube and valve but still get smoke sometimes, it's
> bluish.
Is the breather tube ALSO clean, and are the valve cover baffles not
sludged up?
> Are my rings worn?
If the PCV system is clear, then almost certainly the oil control rings are
worn.
Eventually the oil burning will be consistent. Watch your oil level: It
will go down quickly now.
> I understand that if the rings are worn there's little to nothing one
> can do about it.
Correct. Rebuild/replacement time. The rings have worn to the point that
they've relaxed their hold on the cylinder wall.
> Does a heavier oil help?
A 20W-50 *might* help a little. You've got nothing to lose in trying it.
TeGGeR®
www.tegger.com/hondafaq/
sonicsc1
May 10, 2008 08:32 PM
RayGun
Aug 14, 2005 12:32 AM
RayGun
Aug 12, 2005 02:30 PM
SoCalMike
Jul 7, 2005 03:22 AM
mike113
May 4, 2005 04:44 PM
