how much do stock steelies (wheels) weigh?
I think the base ones are 15lbs(I hear most everyone say high 16's to mid 17's for the stock sport rims)
But I would definately try a search...
This is the perfect question for a search too.
good luck, and enjoy your anticlimactic findings
peace
peace
Last edited by Snap Fit; Mar 21, 2008 at 04:14 AM. Reason: whooops...kinda typed that up 5 kinds of wrong...
You have options with the stock 14x5.5" wheels. I don't think the steel wheels are light.
Stock 15x6 Sport rims are 17.45 lbs each
Stock 15" tire and rim are 34.4 lbs each
see
https://www.fitfreak.net/forums/fit-...ck+15x6+weight
If you stick to 14" rims you can get something really light and not expensive at tirerack. 175/65-14 stock tires. 195/60-14 performance tires. Or 195/55-14 Racing R compound tires for track or autocross.
Ten 14x6" rims at Tirerack.com that will work with TPMS if you have a 2008 or later Fit-
Borbet Type CA $96 +38 et 16.3 lbs Silver
Borbet Type H $72 closeout +38 et 15.5 lbs Silver
Kosei K1 TS $104 +38 et 9.3 lbs, Light grey or Silver
Kosei K3 $105 +38 et 10.6 lbs, Silver
MSW Type 14 $65 +38 et 14.5 lbs, Silver
MSW Type 15 $65 +38 et 15.5 lbs, Silver
O.Z. Superturismo GT $138 +36 et 15 lbs, Bright Silver
O.Z. Superturismo WRC $138 +36 et 15 lbs, White
Sport Edition D5 $69 +38 et 12.8 lbs, Silver
One 14x5.5" rim
Rial Campo $83 +43 et 14.2 lbs, Silver
Talk to Jim@tirerack for more info.
see
One 14x5.5" rim
joshgd3
Aug 5, 2008 01:22 PM
