Help!..trying to remove door panels to install speakers
Old Mar 25, 2008 | 06:58 PM
micchung's Avatar
I'm trying to remove the door panels so i can install rear the speakers..
I've removed the screw from the door handle, and tried to remove the plastic on the side arm rest, ive tried to push in the tabs but they dont seem to move..
how and which direction do i need to pull? ...i'm a bit scared of breaking something. or anyone got any pics on how this is done?
Old Mar 25, 2008 | 07:55 PM
koolkevin1107's Avatar
those tabs are only there to hold it in place, they are not button tabs. Just pull down very lightly on the arm rest piece and pull the piece forward, those tabs on the bottom don't move.
Old Mar 28, 2008 | 11:28 AM
raton's Avatar
I used a flat-head screwdriver (w/ a shop towel to avoid scratching trim) to push in the three clips. I then used a trim/clip remover (from AutoZone or Checker Auto, I forget which...plus the shop towel)...
...then slowly pryed under the arm-rest cover (from front-to-rear). The arm-rest cover eventually pops off.
I also used the clip/trim remover to pop out the 7 clips that surround the outter-edge of the door panel.
If u haven't checked it out yet, this link has step-by-step instructions to remove the door panels [ Front Door Panel Removal/Installation ].
Old Mar 28, 2008 | 03:30 PM
micchung's Avatar
thanks i'll give it a try....
is it just me?.... i cant see the pic's in the step by step instructions??
Old Mar 28, 2008 | 07:20 PM
raton's Avatar
You should be able to click on the small icon/button within the list of steps....a more detailed list of instructions and/or diagrams should then be shown/expanded. If that doesn't happen, you may have pop-ups blocked in your brownser. If pop-ups are blocked, u could just enable them for that particular site. Good luck.
Old Mar 28, 2008 | 07:34 PM
micchung's Avatar
thanks .... firefox didn't like that page.. IE works ok
Old Mar 29, 2008 | 07:12 PM
raton's Avatar
Great! Just as a side note: While sound deadening the front door....I accidently broke the metal clip clean off the Fit's OEM speaker when I brutishly removed it from the front door. I wish I saw this diagram before I started. The pic is from http://www.hondafitjazz.com/front_door.htm
ps: The OEM speaker w/ the broken metal clip went back in just fine. The door panel trim & speaker tabs at the bottom keep it securely/snuggly in place. I plan to replace the front components anyways...Gw, eventually.
oblio125
Aug 25, 2012 01:05 AM
tight_fit
Nov 22, 2011 11:47 AM
pp0225
Aug 4, 2011 10:25 PM
Ciggy
May 14, 2010 03:25 PM
sy11580
Dec 20, 2008 08:20 PM
