94 accord, no oil to top of engine- Oil light on
Old Jul 11, 2005 | 03:03 AM
Fightthemetermaid@gmail.com
Guest
Posts: n/a
I have a 94 accord EX with 310000km. Yesterday I was driving over
some rough dirt roads ( I mean REALLY rough) and the oil light came on.
it blinked intermittently at first and then came on steady. I thought
that the oil was low, so I added a bunch of oil. I waited til the next
day, and there is no sign of leaks and the dipstick reads high.
When I take the oil cap off, It is quite dry, and I have to poke my
finger in a fair way to get it even slightly oily.
My only thoughts are to check the intake or replace the oil pump as
if the engine is dry, It does not make sense that it is the sender.
Any advice would be really appreciated,
Thanks,
Matt.
SoCalMike
Guest
Posts: n/a
Re: 94 accord, no oil to top of engine- Oil light on
which indicates lack of pressure... not necessarily lack of oil.
reading too high isnt good either.
but it could be, and going over the rough roads might have loosened an
intermittant connection
id drain the oil to where its supposed to be, check the connection to
the sender, unplug, clean, replug.
if light still goes on, a real oil pressure check is necessary.
> Thanks,
> Matt.
Old Jul 11, 2005 | 09:18 AM
TeGGeR®
Guest
Posts: n/a
Fightthemetermaid@gmail.com wrote in
news:1121060909.215224.256770@g43g2000cwa.googlegr oups.com:
Check the wiring and connectors at the oil pressure sender unit in the
block.
To check the oil to the top end, run the engine and remove the filler cap.
If you see splashes (watch your clothes), oil feed is fine.
TeGGeR®
www.tegger.com/hondafaq/
Old Jul 12, 2005 | 07:11 AM
Arthur Russell
Guest
Posts: n/a
Inspect the bottom of your oil pan. My first guess would be that you hit
a rock which deformed the pan in the wrong place, and broke the snorkel
off the intake for the oil pump. In other words, you may very well have
low/no oil pressure. I'm not sure how easy this is to do the these
engines, but this was particularly easy to do with the I4's that VW made
in the rabbit/gti cars.
Good luck,
Arthur
>> Thanks,
>> Matt.
Old Jul 12, 2005 | 03:30 PM
Guest
Posts: n/a
Thanks for all the suggestions.
I have just removed the oilpan, and everything inside looks
pristine. The snorkel is not dented at all and the screen is
completely clean.
All I can think of now is changing the oil pump.
If anyone has any suggestions before I start this I would really
appreciate it.
I have rarely heard of the oil pump failing- Is this common?
Thanks,
Matt
Old Jul 13, 2005 | 12:05 AM
jim beam
Guest
Posts: n/a
> completely clean.
> appreciate it.
> Thanks,
> Matt
like tegger says, check the feed by watching for oil circulation under
the top cap. after that, check the sender circuit. the light comes on
when the lead is grounded. if it's trapped somewhere, it could be
making ground.
in answer to your question, no, it's extremely uncommon for a pump to
suddenly fail. wear out, sure. fail? no.
clicq
Jun 29, 2011 07:18 AM
harry
Oct 16, 2005 01:31 AM
teaka
Sep 24, 2005 10:11 PM
techman41973@yahoo.com
Sep 11, 2005 07:53 AM
mike113
May 4, 2005 11:16 AM
