1997 Civic LX Compression
Old Jul 12, 2005 | 07:55 PM
chibitul
Guest
Posts: n/a
Hi,
I had my mechanic check the compression on a 1997 Civic LX, he said
it's fine. when I picked up the car, I got the printed results: all 4
cylinders 160 psi (give or take 1 psi). The mechanic wasn't there, and
the cashier didn't know the spec values. From the message the mechanic
left on my voicemail I understand it''s OK, but I was just wondering
what those values should be for a good 1997 Civic LX Engine (i.e. when
it was new, and for a well taken care of engine).
Thanks
Professor
Guest
Posts: n/a
Re: 1997 Civic LX Compression
160PSI is a very good reading... I would think new wouldn't be much
higher. Don't think you have any problems there.
Professor
Check out FlashAlert at www.telstar-electronics.com
chibitul wrote:
> Hi,
> Thanks
Old Jul 13, 2005 | 12:05 AM
jim beam
Guest
Posts: n/a
chibitul wrote:
> Hi,
> Thanks
why do you care? a lot of manufacturers don't even specify a
compression reading because it's too hard to get consistent numbers.
all the compression test is good for is measuring /relative/ differences
between cylinders as per a head gasket or burnt valve problem.
bottom line, you're lucky you have an honest mechanic. unscrupulous
ones would take your desire for such a test as an opportunity to
diagnose an "imminent problem" and relieve you of several thousand
dollars for a rebuild.
SoCalMike
Guest
Posts: n/a
jim beam wrote:
> chibitul wrote:
>> Hi,
>> Thanks
> compression reading because it's too hard to get consistent numbers. all
oh, lemme go out to the garage and check...
184 psi nominal
135 minimum
no more than 28psi difference between cylinders.
isnt the internet great?
dave92029
Jun 1, 2014 10:08 AM
charlee
Aug 12, 2005 08:30 AM
Rocky
Jul 22, 2005 02:36 AM
chibitul
Jul 16, 2005 02:38 PM
yahmed
May 22, 2005 10:16 PM
