removing the head unit
Old Mar 30, 2008 | 11:21 AM
filmcarp's Avatar
Hello, New member here. I have been a member of the element owners club for a while and I hope this one is as helpful. I have an 07 fit sport. My son just finished shoving pennies into the cd player. I am looking for instructions to remove the head unit so I can clean it out, but I haven't found much. Any help would be appreciated.
Old Mar 30, 2008 | 12:11 PM
soujiro25's Avatar
PM me your email.. i can scan and email the instructions later this evening.. i got them from crutchfield..
basically if you want to try doing it.. there's a bottom screw under ac controls.. undo screw and pry off underneath cover.. from there.. there's two screws.. on the left and right that are deep when looking underneath.. undo those..(they attach the radio unit to brackets) then go for the glove box.. pry off cover underneath the glove box, take off two screws on bottow of glove box hinges.. undo three cables coming from ac controls.. there like blue orange purple? you would squeeze the white plastic tip and pull off cable circles.. and then pull to remove metal clip holders..(that was easiest for me.. one of the three cables does require you to unscrew a bold/screw to pull it off..
nows the bitch.. there's these metal clips.. around the radio unit.. tight as f***.. if you can get two people to pull, probably better.. i wouldn't!!! recommend using a screw driver to pry, it's too tight.. it'll just eat up your dash and radio at the corners.. me i pulled from the bottom.. which is still kinda risky.. after the fact.. i saw a picture that tells you to push from behind reaching in from the glove box area.. using a socket tool.. so probably get one person to do that.. and one to pull from the bottom.. it'll pop out with some clips flying.. after that.. there will be some cables from the radio.. to detach.. and then your cables for the passenger/etc airbag light.. and ac controls.. from the bottom.. crutchfield.. didn't show this step properly.. pm again your email and i can send instructions in afternoon.. going to getty right now.. byebye!
Old Mar 30, 2008 | 02:49 PM
mnapuran's Avatar
Post the scan of the instructions... would be a good resource to have online. That or email them to me and I'll post em.
Old Mar 30, 2008 | 09:29 PM
tmpkFit's Avatar
Mike,
I just got done doing this, soujiro is right...it really feels like you are going to break something pulling the head out. If you haven't gotten the instructions yet, here's a link to the installation instruction for the discontinued "Music Link" which give you the Honda instructions. http://www.bernardiparts.com/Images/..._musiclink.pdf
I found starting at the bottom right and working my way around counter clockwise rather than pulling straight out to be helpful.
Mark
Old Mar 30, 2008 | 09:44 PM
billmus86's Avatar
My Lips Bigger!
u can check the hvac diy link in my sig there are some good pics** to give you an idea about how to do it - if you havent started yet
edited** below**
Last edited by billmus86; Mar 30, 2008 at 09:45 PM. Reason: ** well one- sorry i forgot what was there i thought there was more on the removal
Old Mar 31, 2008 | 02:36 AM
soujiro25's Avatar
PM me your email.. i have scans for radio and front doors if you can post em' up..
Old Mar 31, 2008 | 11:04 PM
mnapuran's Avatar
Old Mar 31, 2008 | 11:20 PM
billmus86's Avatar
My Lips Bigger!
taym12
Nov 13, 2011 04:43 PM
crazysickrider
Nov 1, 2009 11:37 AM
E = Mc2
May 29, 2009 01:37 PM
Rod2Rice
Jun 23, 2008 06:16 AM
mattschechter
Jul 12, 2006 02:17 PM
