1991 honda accord transmission
Old Jul 13, 2005 | 01:51 AM
automite
Guest
Posts: n/a
my car makes a hummmmming sound or a sound that might reflect to a wheel
bearing when in drive and it reaches about 5 mph and does not stop until
it returns under 5 mph the transmission still has a lot of torking power i
need some help on where to start on fixing the problem
Old Jul 13, 2005 | 07:30 AM
TeGGeR®
Guest
Posts: n/a
Re: 1991 honda accord transmission
"automite" <twocoops2000@aol.com> wrote in
news:933bbfc3b96ab5544a3ff2f65079e05f@localhost.ta lkaboutautos.com:
> wheel bearing when in drive and it reaches about 5 mph and does not
> stop until it returns under 5 mph the transmission still has a lot of
> torking power i need some help on where to start on fixing the problem
Manual or auotomatic? That's pretty important.
TeGGeR®
www.tegger.com/hondafaq/
Old Jul 13, 2005 | 02:41 PM
motsco_ _
Guest
Posts: n/a
What's the mileage, and when did you last change the tranny fluid. What
did you use?
'Curly'
Old Jul 14, 2005 | 01:31 AM
automite
Guest
Posts: n/a
Manual trans
don't know about the fluilds just got the car
A little history. the guy had a new trans put in before i got it. the
cylinold has gone out on the trans it won't change over to 3-drive 1 and 2
ok and R the fluids are over full on the trans.
Old Jul 14, 2005 | 10:27 AM
TeGGeR®
Guest
Posts: n/a
news:7060fb89f34a64da57470406107561b5@localhost.ta lkaboutautos.com:
> Manual trans
> and 2 ok and R the fluids are over full on the trans.
Your writing is confusing.
As I understand this, you have a '91 Accord with a replacement manual
transmission. There is a humming noise that only occurs at or below 5mph.
You cannot shift into third gear, but you can shift into any of the lower
gears.
Questions:
1) Can you shift into 4th and 5th?
2) Does the noise happen if you're accelerating, decelerating, or coasting?
3) When you say "cylinold", are you referring to the MASTER or SLAVE
cylinders?
4) Has the cylinder that has "gone out" been replaced?
It is odd that you can't change into 3rd, but you can into the lower gears.
Usually it's the lower gears (especially reverse) that people have trouble
with.
At first blush, I'd say to
1) Check for loose heat shields on the exhaust, or for other loose parts
that may vibrate, and
2) change the oil for genuine Honda MTL, and see if the noise changes.
TeGGeR®
Old Jul 15, 2005 | 12:42 AM
automite
Guest
Posts: n/a
question 1 automatic not manual
? #2 accelerating and when i get over 5 mph
? #3 yes
? #4 no
this is a noise that sounds like a bearing that has gone bad sounds like a
wmwmwmwmwmwmwm and only does it in drive or 1 or 2 but won't go into drive
Old Jul 15, 2005 | 08:48 AM
TeGGeR®
Guest
Posts: n/a
news:e2572b5a4f87eb790a22364eeab0bf81@localhost.ta lkaboutautos.com:
>> 5mph. You cannot shift into third gear, but you can shift into any of
>> the lower gears.
>> Questions:
>> or coasting?
>> SLAVE cylinders?
But two messages ago you specifically told me it was a manual:
"Manual trans
don't know about the fluilds just got the car"
OK...
> ? #3 yes
You are referring to *both* the master and slave cylinders, neither of
which an automatic has? I'm even more confused now.
> ? #4 no
> like a wmwmwmwmwmwmwm and only does it in drive or 1 or 2 but won't go
> into drive
Does the transmission growl when you accelerate froma standstill?
Check the fluid level. Get a flush and refill with appropriate fluid. If
noise persists, go see a good garage. Strange noises in an automatic often
mean serious problems.
TeGGeR®
Yeahhhok
Jun 21, 2018 12:31 AM
fittiestfittyfit
Aug 4, 2017 06:50 PM
aerorea
May 15, 2005 07:30 PM
lgl
May 4, 2005 11:16 AM
cwoodard@comcast.net
