15" Civic rims on Fit?
Old Apr 4, 2008 | 02:34 PM
JCLW's Avatar
Planning on putting snow tires on the OEM steel rims next winter so I'm looking at picking up some 15" Civic alloys to use in the summers, since they're much easier to find around here then Fit sport rims.
Obviously I need 4x100.
Most Civic rims seem to be 15"x6" with a 45mm offset.
I would probably use 185/60R15 rubber (which is a close match to 195/55R15) as I'm often driving on country/bad roads.
Any reason this setup would have problems? It seems fine to me but I'm sure others here have more experience in these matters.
Old Apr 4, 2008 | 02:36 PM
RDS's Avatar
RDS
Senior Member
What year Civic? The 06+ are 5 lug, but I'm pretty sure the 01-05s are 4 lug.
Old Apr 4, 2008 | 06:19 PM
mimpi's Avatar
Im currently running 185/60/15 the same exact setup u ask on a steel rims. i dont see why there should be a problem. 60 profile does helps alot absorb those bumpy roads for sure.
Old Apr 4, 2008 | 10:26 PM
TOOL's Avatar
What year civic wheels?
Older Si wheels are hot, i almost bought a set.
Tyler
Old Apr 4, 2008 | 11:17 PM
solbrothers's Avatar
boooooo!
NEW oem wheels on older honda, ok. OLD oem wheels on newer honda, no!!
Old Apr 4, 2008 | 11:19 PM
TOOL's Avatar
boooooo!
I disagree 100% lol!
Some old OEM wheels look crappy, and some are off the hook!
Tyler
Old Apr 4, 2008 | 11:23 PM
LS mesh on a fit, YUCK!
fit sport wheels on a LS, HELLZ YA! :P :P
Old Apr 4, 2008 | 11:25 PM
TOOL's Avatar
Are you kidding lol!??!!! LS mesh on Fit looks insanly nice! Fit stockies on a teg...ehhh. I put my stocks on my Teg, 55 offset looked wack.
Tyler
Old Apr 5, 2008 | 09:46 AM
JCLW's Avatar
Probably some of these:
They seem to be found on 7th gen civics (01-05). I think the Si ones but I'm not 100% sure.
I'm not too concerned about looks (as long as they're not so hideous they scare the lugnuts off the studs). The less likely they are to be stolen the better.
We run 185/60R15 on the other half's Echo so that's another reason I'd like to use that size on the fit.
Kingfisher
Feb 1, 2011 09:43 AM
skygrabber
Jan 21, 2009 07:19 PM
zukered
Oct 23, 2008 09:05 AM
stendzme
Sep 22, 2008 02:50 PM
photofit
Dec 2, 2006 02:21 AM
