Dimmer Question
Old Jul 18, 2005 | 01:45 PM
Brandy Alexandre
Guest
Posts: n/a
Dimmer Question
Okay, so I was going to bid on a dimmer on eBay to get my dash lights
on again, but I have a question. Is it really the dimmer? When the
car is in gear, the dimmer will make the gear its in... dimmer and
brighter, so it makes me wonder if that's really the problem or if the
bulb is out. Anyone have experience with this? And, can you tell me
where the bulb is so I can look at it. I have the instrumenation
portion of the dash open and took out the dimmer switch, but not sure
where to look for the bulb and what more I should take apart
(I like taking things apart.) :)
Brandy Alexandre®
http://www.swydm.com/?refer=BrandyAlx
Well, would you?
Old Jul 18, 2005 | 09:36 PM
TeGGeR®
Guest
Posts: n/a
Re: Dimmer Question
"Brandy Alexandre" <brandyalx@kittylittercomcast.net> wrote in
news:1121707730.799e0e84f4bb57f8c04bcf65ce1976c9@t eranews:
What kinda car is this?
Make?
Model?
Year?
If the lights actually dim and brighten when the dimmer is operated, then
the dimmer is fine.
TeGGeR®
www.tegger.com/hondafaq/
Brandy  Alexandre
Guest
Posts: n/a
Re: Dimmer Question
TeGGeR® <tegger@tegger.c0m> wrote in rec.autos.makers.honda:
>> lights on again, but I have a question. Is it really the dimmer?
>> When the car is in gear, the dimmer will make the gear its in...
>> dimmer and brighter, so it makes me wonder if that's really the
>> problem or if the bulb is out. Anyone have experience with this?
>> And, can you tell me where the bulb is so I can look at it. I
>> have the instrumenation portion of the dash open and took out the
>> dimmer switch, but not sure where to look for the bulb and what
> Make?
> Model?
> Year?
> operated, then the dimmer is fine.
I'm sorry. I knew I forgot something. 1991 Honda Civic 2-door HB.
Brandy Alexandre®
Well, would you?
Old Jul 18, 2005 | 11:02 PM
TeGGeR®
Guest
Posts: n/a
Re: Dimmer Question
"Brandy Alexandre" <brandy@kamikaze.orgy> wrote in
news:1121736419.55e1e6cbf36e66e8651e5ba422617f6f@t eranews:
My manuals only go back to '92, but this is something that is common to
most cars in general.
Gauge lighting is accessed from the back of the circuit board that makes up
the rear of the instrument cluster. You remove the bezel and the cluster
with by unclipping/removing a number of clips/screws. The bulbs are held in
their sockets with a bayonet-lock plug, like many other bulbs on the car.
Should be (/should/ be) obvious when you've got the cluster loose. Some of
the bulbs are for stuff like the parking brake light, and others are
general gauge lighting. The ones for specific lights are ordinarily
directly behind their targets.
If you can get the power connector plugged in, you can test to see which
ones are the ones you want, or you can just physically remove each one and
run current through each one to see if they work.
TeGGeR®
Old Jul 19, 2005 | 07:49 PM
Brandy  Alexandre
Guest
Posts: n/a
Re: Dimmer Question
>> HB.
> common to most cars in general.
> makes up the rear of the instrument cluster. You remove the bezel
> and the cluster with by unclipping/removing a number of
> clips/screws. The bulbs are held in their sockets with a
> Some of the bulbs are for stuff like the parking brake light, and
> others are general gauge lighting. The ones for specific lights
> are ordinarily directly behind their targets.
> which ones are the ones you want, or you can just physically
> remove each one and run current through each one to see if they
> work.
Well, my Midas Touch works again. When I first pulled the cover
completely off (getting the hazard light connector off was a bear),
there was a little board on top with two bulbs and two wires that
ran behind to a third. I thought that was the culprit and took
those out, cleaned contacts, inspected the solder joint and it all
looked fine. I put it back... nothing.
Before I gave up and put it all back together, I took the entire
instrumentation thingie (very technical term) off and looked at it.
I knew the alert lights worked, and the gear lights worked, so I
didn't mess with those, but there were four more bulbs on the
bottom--three large and one small. Took each of those out (they
wore little blue condoms) and cleaned them, checked the filament,
etc. and put them back. I don't have any real tools to check for
power or anything, I just blew at each of the connections and holes
with my computer airduster, pushed and puled on all the connectors,
jiggled all of the wire harnesses and tested it again. Nothing.
Fuck it. Did all I could do and I put it all back together. Now it
works!!! I "disturbed" the right thing, and I'll probably lose the
light again at the first speed bump, but for now, they work.
Brandy Alexandre®
Well, would you?
Old Jul 20, 2005 | 10:31 PM
TeGGeR®
Guest
Posts: n/a
Re: Dimmer Question
news:1121813377.c3b67170412a9c1407b8043a22ae65cb@t eranews:
There might have been a skin of dust or corrosion that you broke when you
were messing with it. It happens.
TeGGeR®
Old Jul 20, 2005 | 11:35 PM
Brandy  Alexandre
Guest
Posts: n/a
Re: Dimmer Question
>> it works!!! I "disturbed" the right thing, and I'll probably
>> lose the light again at the first speed bump, but for now, they
>> work.
> when you were messing with it. It happens.
Could be. I'm just happy with the light. It looks weird though. It's
been out for literally years.
Brandy Alexandre®
Well, would you?
Old Jul 27, 2005 | 08:30 AM
questmoble
Guest
Posts: n/a
Re: Dimmer Question
I have a 99 passport.... Dimmer lites didn't work... Replaced bulbs... Same
problem.... Went 2 a salvage yard... Replaced dimmer control($10.00)...
Solved problem!
Old Jul 27, 2005 | 11:30 AM
motsco_ _
Guest
Posts: n/a
Re: Dimmer Question
> Solved problem!
$10 ! I wonder what the dealer wanted for the same part. You've done well.
'Curly'
hotlilmike
Jan 10, 2015 01:59 AM
markyta
Jul 23, 2013 01:31 AM
skittles
Mar 9, 2008 03:57 PM
siguy
Feb 28, 2006 12:53 PM
neil.goradia@gmail.com
Sep 22, 2005 10:30 AM
