99' Accord Brake Squeak - just replaced brakes, rotor and rotor again
Old Jul 18, 2005 | 11:02 PM
RvBTucker@gmail.com
Guest
Posts: n/a
I'm hoping someone has a good idea for this one. I've got a 99 Accord
Ex 4-cyl. I just replaced the front brakes and rotors less then 2
months ago. It's got 95k on it right now and noticed that shortly
after replaceing the rotors and brakes that it started to squeak again.
Squeaking only occurs at slow speeds at first and then a few weeks
later, it was bad enough that it was audible at higher speeds and you
could feel a pulsating in the brake pedal when braking. The left front
rotor was obviously getting some hot spots on the outer half of the
rotor. I decided to replace the rotor in hopes that it was some form
of defect in the rotor, but less then a week later it's starting to
squeak again.
FYI, the pads slide easily so there shouldn't be any dragging. I could
go out and replace the pads again, but I hate to start sinking money
into something that may not fix the problem.
Thanks in advance for any help or suggestions.
TeGGeR®
Guest
Posts: n/a
Re: 99' Accord Brake Squeak - just replaced brakes, rotor and rotor again
RvBTucker@gmail.com wrote in
news:1121741238.808056.73460@f14g2000cwb.googlegro ups.com:
1) Are you using OEM parts?
2) Had the anti-squeal shims on the backs of the pads been reinstalled?
3) Are you a gentle braker?
> rotor.
That's glaze. You may be braking too softly, especially first thing in the
morning, and turning morning rust into glaze. Glaze can be easily power-
sanded or wire-brushed off the rotors and pads.
TeGGeR®
www.tegger.com/hondafaq/
Old Jul 19, 2005 | 02:58 AM
SoCalMike
Guest
Posts: n/a
Re: 99' Accord Brake Squeak - just replaced brakes, rotor and rotoragain
did you apply any "anti-squeal" to the back of the pads?
Old Jul 19, 2005 | 06:55 AM
Professor
Guest
Posts: n/a
These guys are right... you must install the anti-squeal hardware
correctly to eliminate your problem.
Professor
Check out FlashAlert at www.telstar-electronics.com
Old Jul 19, 2005 | 11:30 AM
RvBTucker@gmail.com
Guest
Posts: n/a
Thanks for the suggestions all.
I am not using OEM pads/rotors. In this respect, does anyone know what
type of pad the OEM pads are, maybe I've got the wrong type of pad?
The anti-squeal shims are installed and I have used the anti-squeal gel
to the back of the pads.
I'm typically a pretty gentle braker.
Old Jul 19, 2005 | 09:31 PM
SoCalMike
Guest
Posts: n/a
on second thought, im thinking one of your rotors is warped, due to the
shimmy you say you feel. might be a stuck caliper? have you tried
bleeding the system and flushing the fluid?
non-OEM pads are often a bit noisier than OEM. thats what you get in
return for saving a few bucks. to me, a little noise doesnt bother me.
Old Jul 20, 2005 | 09:32 AM
RvBTucker@gmail.com
Guest
Posts: n/a
Haven't done the brake fluid flush yet, but it's due for it. I'll try
and give that a try this weekend.
Old Jul 20, 2005 | 10:31 PM
SoCalMike
Guest
Posts: n/a
yeah its due- every 3 years. some new fluid in there might sort the
problem out.
phenoyz
Jun 3, 2014 11:52 PM
wskwong
Jan 26, 2010 12:13 PM
cosza
Aug 9, 2005 01:30 AM
Beerman182
Jun 27, 2005 08:22 AM
srcfyd
May 22, 2005 10:16 PM
