How to determine radiator mfg?
Old Jul 19, 2005 | 02:45 PM
DesignGuy
Guest
Posts: n/a
I've got a 1995 Civic LX, and have had the radiator replaced at a garage due
to overheating. I want to replace the radiator cap (also replaced around the
same time with a non-OEM cap) to an OEM cap as recommended in this
newsgroup.
A call to the Honda dealer find that there are two different caps, depending
on the manufacturer of the radiator (Toyo or Denzo).
Problem is, I can't find any identification on the aftermarket radiator to
identify which one it is.
Old Jul 19, 2005 | 07:49 PM
TeGGeR®
Guest
Posts: n/a
Re: How to determine radiator mfg?
"DesignGuy" <dontbother@nowhere.com> wrote in
news:d5bDe.188111$nG6.28302@attbi_s22:
> garage due to overheating. I want to replace the radiator cap (also
> replaced around the same time with a non-OEM cap) to an OEM cap as
> recommended in this newsgroup.
> depending on the manufacturer of the radiator (Toyo or Denzo).
Did the dealer tell you what differences there are between Toyo and Denso
rad caps? They'rs all made by ND as far as I know.
> radiator to identify which one it is.
If you've got an aftermarket rad (as I do), then the manufacturer of your
original rad is irrelevant.
The outside diameter of the cap should tell you what you need. Mine
measures 1-3/4" across.
And your rating is 0.9 bar, or 13 lbs.
TeGGeR®
www.tegger.com/hondafaq/
Old Jul 19, 2005 | 09:31 PM
DesignGuy
Guest
Posts: n/a
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns9698C41F2FE25tegger@207.14.113.17...
The dealer didn't specify the difference. Also, my after-market rad cap has
1.1 printed on it (1.1 bar?), so perhaps I'm using the wrong cap after all.
I'll take the car to the dealer tomorrow and see about getting an OEM cap.
jim beam
Guest
Posts: n/a
1.1bar will keep the lid on overheating better than 0.9bar will.
check [replace] your thermostat - need to replace the rubber gasket it
sits in at the same time - and see how you go. after that, check for
head gasket, leaks, blockages, etc.
Old Jul 19, 2005 | 11:26 PM
TeGGeR®
Guest
Posts: n/a
jim beam <nospam@example.net> wrote in
news:pJWdnW0NCtIzO0DfRVn-hw@speakeasy.net:
>> cap has 1.1 printed on it (1.1 bar?), so perhaps I'm using the wrong
>> cap after all.
>> cap.
The '95 Civic should be using a 1.1 bar cap.
Modern caps don't even begin to hold pressure until the fluid starts to
boil anyway.
TeGGeR®
jim beam
Guest
Posts: n/a
>>>cap after all.
>>>cap.
> boil anyway.
http://www.biggreenegg.com/boilingPoint.htm
the cap ensures you keep your coolant liquid even when you're up in the
mountains.
TeGGeR®
Guest
Posts: n/a
jim beam <nospam@example.net> wrote in news:RJWdndOy5oeALUDfRVn-
pA@speakeasy.net:
>> boil anyway.
> mountains.
Yes, but the cap does not hold pressure UNTIL the fluid boils, regardless
of what the boiling temperature is. That's why you have that jiggly dangly
thing (get your mind out of the gutter) on the bottom of the cap.
TeGGeR®
Fitguy07
Sep 19, 2015 09:23 AM
BlackPearlFIT
Jul 19, 2012 05:57 PM
HondaFitted2007
Oct 9, 2008 01:18 AM
R. P.
Sep 4, 2005 06:37 PM
spacetrax@wi.rr.com
May 18, 2005 11:20 PM
