My Fit yelled at me
Old Apr 14, 2008 | 04:04 AM
Blaw's Avatar
My Fit yelled at me
So I came home, parked in the garage, pushed the gear into park, pull the parking brake, take out the keys, open the car door, one foot out, and then the car's horn went off - as if the alarm was tripped!
After recovering from my heart attack, I pushed the unlock button on my remote to make the Fit be quiet. "Shut up Fit!"
So the weird thing is, I have a base fit. My car does not have an alarm installed, only keyless entry.
Any one else (sport or base) with a similar experience?
What the heck happened??
Is the car discovering its consciousness??
Old Apr 14, 2008 | 04:45 AM
Edison Carasio's Avatar
It's going to eat you while you sleep.
Old Apr 14, 2008 | 06:22 AM
Rob22315's Avatar
The keyless entry can honk the horn but it normally doesn't happen that way. If you press the lock button on the keyless entry two times, the second time it will honk the horn confirming that you've successfully locked the vehicle. If you don't hear the honk on the second press, then the car isn't locked. Note that you have to wait 1-2 seconds between presses.
I can't say that's your problem, I'm only confirming that the keyless entry can honk the horn.
The panic button on the keyless entry will honk the horn multiple times, any chance the panic button got pressed while the keys were in your pocket or hand?
Old Apr 14, 2008 | 07:49 AM
cojaro's Avatar
It’s going to eat rape you while you sleep.
Possibly there's a blown fuse, or worse yet, a short somewhere. I don't know what to tell you but to protect your backside
Old Apr 14, 2008 | 08:16 AM
billmus86's Avatar
My Lips Bigger!
spaghetti!!
lol
Old Apr 14, 2008 | 08:26 AM
hmgFIT's Avatar
trust me, you accidentally hit the horn on the steering wheel, it's sensitive...
Old Apr 14, 2008 | 09:01 AM
SPON FIT's Avatar
thats what im thinking
Old Apr 14, 2008 | 10:41 AM
kelsodeez's Avatar
UNBANABLE
maybe you accidentally pressed the panic button on your keys. your fit thought you were getting raped!
Old Apr 14, 2008 | 11:19 AM
TOOL's Avatar
Thats what i thought, but does a base have a panic button???
Tyler
Old Apr 14, 2008 | 11:20 AM
The base model I think just come with a plain old key.
Old Apr 14, 2008 | 01:10 PM
Blackberryfit's Avatar
I call hit the horn!
Your Fit is out to get you
Old Apr 14, 2008 | 03:21 PM
Rob22315's Avatar
The OP has keyless entry which includes a panic button. It's on a separate fob.
Old Apr 14, 2008 | 05:10 PM
Steeldog's Avatar
Ha-ha, Mr. Fit yelled at you!
Old Apr 14, 2008 | 10:07 PM
Blaw's Avatar
Indeed, I do have a working panic button. I do not think that I pressed it though. The button is recessed and it has to be held down for it to activate.
Maybe I am paranoid, but I am more concerned about there being a short or blown fuse. Installing the keyless entry was easy, but the wiring under the dash is a tangled mess.
I guess I can double check the fuse and wiring, making sure the connections are tight.
MEATBABY
Mar 13, 2019 01:51 PM
thorton0
Apr 30, 2018 09:36 PM
atikovi
Dec 19, 2008 08:14 PM
2jmotorsports
Sep 4, 2008 05:23 PM
Frest2k
May 20, 2008 08:07 AM
