Honda radiator boil
Old Jul 20, 2005 | 04:32 PM
Dave Packham
Guest
Posts: n/a
Honda radiator boil
My 93 Honda accord had radiator problems and leaks. I replaced the
thermostat and the radiator. it doesn't boilover anymore but I still can
hear that the water is boiling into the overflow container when I turn off
the car. when I turn off the car the fans stop... if I leave it for a few
minutes the fans turn back on. I have replaced the thermo with the
suggested value one. are the fans not turning on enough? is there an
electronic sensor that is turning on too high? shouldn't the water temp
stay below boil?
Thanks
Dave Packham
Old Jul 20, 2005 | 06:23 PM
TeGGeR®
Guest
Posts: n/a
Re: Honda radiator boil
"Dave Packham" <dave.packham@utah.edu> wrote in
news:dbm8sq$v6$1@vegh.ks.cc.utah.edu:
> can hear that the water is boiling into the overflow container when I
> turn off the car. when I turn off the car the fans stop... if I leave
> it for a few minutes the fans turn back on. I have replaced the
> thermo with the suggested value one. are the fans not turning on
> enough? is there an electronic sensor that is turning on too high?
> shouldn't the water temp stay below boil?
Replace the rad cap.
TeGGeR®
www.tegger.com/hondafaq/
Old Jul 21, 2005 | 03:36 PM
Dave Packham
Guest
Posts: n/a
Pretty sure the new radiator came with one but ill check. Would that be
cause of the water getting to hot? Or is it that the cap is loosing pressure
and allowing it to overflow? Is the water temp always in the boiling range,
but just being contained?
Thanks
Dave P
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns9699B95AD637Ategger@207.14.113.17...
> TeGGeR®
Old Jul 22, 2005 | 07:33 AM
Professor
Guest
Posts: n/a
It's certainly possible that at times the coolant temperature is well
above 212F... and you're absolutely right that it's the pressure that
keeps that boiling in check.
Professor
www.telstar-electronics.com
Old Jul 22, 2005 | 08:34 AM
TeGGeR®
Guest
Posts: n/a
news:dbot83$610$1@vegh.ks.cc.utah.edu:
> be cause of the water getting to hot? Or is it that the cap is loosing
> pressure and allowing it to overflow?
Yes, that's my thinking. It might be something else, but it's the cheapest,
simplest and most obvious thing to try first and you should to it
immediately, not tomorrow or the next day or the day after that.
If cap replacement does not fix the trouble, then you should suspect the
head gasket.
> boiling range, but just being contained?
No, it's only /sometimes/ in the boiling range. Theoretically, it's always
supposed to be at 194F, the rating of the thermostat.
The combustion chamber runs at about 2,100F, but coolant flow and radiator
function are supposed to be such that the coolant itself does not get hot
enough to actually boil. The pressure imparted by the action of the rad cap
is supposed to retart boiling by holding the system to about 13-15 lbs.
Modern rad caps don't even hold pressure at all /until/ the fluid begins to
boil, at which point pressure builds rapidly and the cap seals, quelling
the boiling.
TeGGeR®
Old Jul 22, 2005 | 04:30 PM
R. P.
Guest
Posts: n/a
> always
> radiator
> hot
> rad cap
> lbs.
> begins to
> quelling
> the boiling.
Hm, that's interesting and prompts me to ask a relevant question, too.
From what you are saying, it should be very rare that the radiotor fan
should kick in after stopping the engine because according to the specs
that fan should only come up if its sensor detects the coolant to be at
223 F, if I recall correctly. But I noticed that my car's fan kicks in
pretty regularly after I pull into my garage and stop the engine, even
if it was not an especially hot day or hard driving. I'm pretty sure my
thermostat works OK as it was just recently replaced with a new one. Is
this normal behavior from a '94 Accord LX? The car otherwise runs
great. I don't recall though that the original radiator cap was ever
replaced.
JP
Old Jul 22, 2005 | 05:31 PM
TeGGeR®
Guest
Posts: n/a
"R. P." <r_pol12gar@hotmail.com> wrote in news:Q4-dnY6g25vj0XzfRVn-
hA@comcast.com:
>> begins to
>> quelling
>> the boiling.
> 223 F,
The cooling fan will come on when the coolant temperature is between 191
and 197F. The thermostat is supposed to open at 194. Once it opens, the
temperature in the block falls rapidly.
The cooling fan will ALSO come on after shutdown if the OIL temperature is
above 226F. At least in the US. Canadian cars may or may not have such a
feature, depending.
TeGGeR®
Old Jul 22, 2005 | 09:31 PM
DesignGuy
Guest
Posts: n/a
news:Xns969BADF35F94Ctegger@207.14.113.17...
> hA@comcast.com:
> >> begins to
> >> quelling
> >> the boiling.
> > 223 F,
Would a defective thermostat cause the cooling fan to *not* come on? I've
bypassed the thermoswitch to have the colling fan always on when the
engine's running (due to some overheating problems), but recently changed
out the thermostat so am curious if that could have been the problem all
along.
Old Jul 22, 2005 | 10:45 PM
TeGGeR®
Guest
Posts: n/a
"DesignGuy" <dontbother@nowhere.com> wrote in
news:5WgEe.171835$x96.45657@attbi_s72:
>> 191 and 197F. The thermostat is supposed to open at 194. Once it
>> opens, the temperature in the block falls rapidly.
Yes, if it makes engine run too cool.
TeGGeR®
cakacon
Mar 2, 2018 12:02 PM
john21031
Nov 26, 2015 01:39 AM
wzard999
Nov 17, 2013 08:58 PM
igoodtoo
Aug 7, 2005 12:31 AM
enravi
May 4, 2005 04:44 PM
