91 Accord temp gauge
Old Jul 23, 2005 | 11:39 AM
rye guy
Guest
Posts: n/a
When the car starts up the temp gauge heads to the center and stays
there. No overheating issues at all, the car has a good thermostat.
Is this behavior by default? What is the fix, if any? I'm not too
inclined to worry about it but my concern is that if it is faulty then
it might not register the proper temp, esp if it's going to overheat.
Old Jul 23, 2005 | 07:32 PM
Professor
Guest
Posts: n/a
Re: 91 Accord temp gauge
So what you're saying is that no matter what temp the engine is... the
gauge always shows mid way? And the needle falls all the way to left
when the key is removed?
Professor
www.telstar-electronics.com
Old Jul 23, 2005 | 09:22 PM
rye guy
Guest
Posts: n/a
Yes - I guess. I've never overheated it so I wouldn't know if the needle
moves into the red, but it goes to center when you turn the car on and
heads left when you turn it off.
> Professor
Old Jul 26, 2005 | 01:45 AM
Trying to Help
Guest
Posts: n/a
Due to faulty thermostat, I've had temp fluctuation on my 91 Accord
before. After fix, the temp is now consistently at between "Neutral
and Drive". If it's there and your fans come on at proper times, don't
worry about it.
> > Professor
cavernap
Aug 20, 2018 12:22 AM
faxe
Jan 18, 2013 03:25 PM
hkjazz
theljnet.com
Jan 2, 2008 12:34 PM
jim beam
Aug 28, 2005 08:46 PM
acellier
Aug 12, 2005 10:34 PM
