Civic brake disk thickness?
Old Jul 23, 2005 | 02:44 PM
chibitul
Guest
Posts: n/a
Hi, just measured the thickness of the front brake disks on my Civics,
but I could not find the minimum thickness engraved on the discks. So I
wonder if any of you knows ths specs, minimum thickness, and if you
also know the maximum thickness (when the discks are NEW) that would
also help (i.e. I could figure out how much I used and how much I have
left.
Civic 2001 LX Manual: 20.80 mm (59k miles)
Civic 1997 LX Manual: 20.25 mm (114k miles)
Thanks.
Old Jul 23, 2005 | 03:33 PM
Elle
Guest
Posts: n/a
Re: Civic brake disk thickness?
> left.
For the 1997, http://www.honda.co.uk/owner/CivicManual/index.html , under
Specifications, then "standards and service limits" says new, the front
rotors are supposed to be 20.9 to 21.1 mm. The service limit is 19.0 mm.
Your 1997's rotors are not even at the halfway point (20.05 mm) for wear.
(This assumes they are not scored badly and thickness is even.)
Majestic's online parts site indicates the 2001 LX and 1997 LX use the same
front rotors.
For your reference, my 1991 Civic LX's front rotors at 168k miles are not at
the halfway point, either, though they're getting close. I do brake a lot
with the engine, as opposed to the front and rear brakes.
While I'm watching thickness variation and one bad score on one of the
rotors, I'm figuring my Civic's rotors are going to last the life of the
car.
Old Jul 23, 2005 | 10:44 PM
ah1244@wayne.edu
Guest
Posts: n/a
When Honda front break pads wear down to a certain minimum thickness, a
pin will start touching the rotor surface when you break, and you will
start to hear a high pitched scratching sound. That is when you change
the pads. I think the 2001 Civic is the same way (I do not know whether
this is the situation with ABS equipped cars-but the LX does not have
ABS as far as I know..........).
> left.
> Thanks.
Old Jul 28, 2005 | 12:33 AM
Pars
Guest
Posts: n/a
> > left.
same
> front rotors.
at
> car.
It's a good thing that I kept my original Honda rotors when I replaced them
for Brembo cross drilled rotors. The Brembo have already survived 4 pads and
190,000km. Hopefully, it won't be too much of a problem to remove 4 years of
rust off the original rotors when the Brembo finally give-up.
Pars
1998 Civic Hatch
Bummbull
Nov 9, 2010 10:46 AM
charlee
Aug 12, 2005 08:30 AM
Rocky
Jul 22, 2005 02:36 AM
chibitul
Jul 13, 2005 12:05 AM
Elle
May 22, 2005 10:16 PM
