which first: pads or fluid?
Old Jul 23, 2005 | 02:44 PM
chibitul
Guest
Posts: n/a
Hi, I am going to replace the brake fluid and also the front pads.
Which one shall I do first, and why? Thanks.
jim beam
Guest
Posts: n/a
Re: which first: pads or fluid?
do them both at the same time.
you need to squeeze the piston back into the caliper anyway to change
the pads, so it's the ideal opportunity to change the fluid if you
squeeze the pads with the bleed valve open. that way, you're not
forcing old fluid back up into the master cylinder and you're ensuring
maximum volume change in the caliper.
Old Jul 28, 2005 | 01:31 AM
johngdole@hotmail.com
Guest
Posts: n/a
I'd flush the brake fluid so when you push back the pistons, you are
pushing clean fluid back.
Check out the Power Bleeder. www.motiveproducts.com
Old Jul 28, 2005 | 02:31 AM
SoCalMike
Guest
Posts: n/a
looks like a $10 bug sprayer with a cap attached. bet i could make one o
those!
Old Jul 28, 2005 | 09:30 AM
jim beam
Guest
Posts: n/a
if you open the bleed valves /before/ pushing the pistons in, you don't
push /any/ fluid back. and you expunge more crud left in the bottom of
the cylinders than you ever can by straight bleeding.
Old Jul 28, 2005 | 10:30 AM
ycleptor2@cs.com
Guest
Posts: n/a
give it a go, daddy-o:
http://www.bmw-m.net/TechProc/bleeder.htm
Gekisen
27
Jun 23, 2019 11:53 AM
fitowner10
Sep 9, 2014 08:36 PM
sh00k
Feb 22, 2013 12:55 AM
kennef
Car Shows, Events, and Racing
Nov 13, 2007 12:27 AM
chibitul
Jul 24, 2005 05:32 AM
