Coil / Ignitor / Main Relay Cont.
Old Jul 26, 2005 | 08:59 PM
jostorama@gmail.com
Guest
Posts: n/a
Greetings,
I asked before about what else to do with a rough idling Accord. I had
replaced the ignitor and fixed the main relay. It still ran rough at
idle and did worse as it ran longer.
Well I cleaned the throttle bottle, put in a new PCV, and a new fuel
filter. All of sudden it was running great, BUT after long it was
idling rough sometimes (not as bad), and now a new problem exists. At
driving RPMs the Tach goes crazy and it runs like poop.
I am thinking its a bad coil, but before I go buy one I wanted to see
what you all had to say. Did I do something wrong? Miss something? Or
am I just taking one problem down at a time that allows other
preexisting problems to run free?
Thanks for all the help
D
TeGGeR®
Guest
Posts: n/a
Re: Coil / Ignitor / Main Relay Cont.
jostorama@gmail.com wrote in
news:1122424501.201375.11430@f14g2000cwb.googlegro ups.com:
> Greetings,
Tach going nuts?
1) Blue wire intermittent connection
2) Igniter going bad.
Check tach connection inside distributor, and at connector block.
How clean is the EACV?
No, not the coil at all.
TeGGeR®
www.tegger.com/hondafaq/
Old Jul 26, 2005 | 10:31 PM
jostorama@gmail.com
Guest
Posts: n/a
Hmmm.
The ignitor is brand new.. Either I connected something wrong OR
something is making it go bad, assuming it is bad. It also runs like
poo while the tach is going crazy....
I'll check the EACV, and the blue wire.
Thanks
Old Jul 27, 2005 | 01:43 AM
Elle
Guest
Posts: n/a
I doubt it's thee main problem, but just to eliminate it: Did you purge air
from the cooling system?
<jostorama@gmail.com> wrote
> Greetings,
> D
Old Jul 27, 2005 | 11:30 AM
motsco_ _
Guest
Posts: n/a
jostorama@gmail.com wrote:
> Hmmm.
> Thanks
Is it the ignitor that has to have heatsink paste on the backside to
prevent it overheating?
'Curly'
Old Jul 27, 2005 | 04:43 PM
jostorama@gmail.com
Guest
Posts: n/a
Yep..
Flyboybob
Aug 7, 2015 06:44 PM
gloryhound
Mar 15, 2014 11:29 PM
jostorama@gmail.com
Oct 17, 2005 10:32 PM
a
Sep 9, 2005 12:37 AM
jostorama@gmail.com
Jul 22, 2005 09:30 AM
