Water on back floorboard, help!
Old Apr 28, 2008 | 01:50 PM
veteran13's Avatar
Last week after two days of heavy rain, I noticed pooling water on the floor board where the rear seats lock in. Has anyone else noticed water getting into the cabin area. It's on both sides in the rear. I really wouldn't had noticed it, but I was cleaning out the car an noticed something on the floor and went to pick it up and it was wet. I pressed the carpet near the seat lock and water just seeped out. I used a towel to get some of it out, but it's still damp. It goes into the dealer today. Hopefully they can find out where it's getting in. If anyone else had this problem and found a solution I'd appreciate their help. The car is only a year old. (the windows were not down)
Old Apr 28, 2008 | 03:23 PM
ive yet to encounter it, but do you have any mods on the car?
might want to get a shopvac and vac all the water out before it
molds.
Old Apr 28, 2008 | 03:28 PM
veteran13's Avatar
No mods. I tried to soak it up with a towel. Hopefully the dealer will figure out where it's getting in. It's suppose to rain here Thursday and Friday. I noticed the seal around the door seems loose compared to other cars I've owned. I'll post if they figure it out.
Thanks for the reply.
Old Apr 28, 2008 | 03:40 PM
hummm... yah, hope they find it real quick.
keep us posted on how it goes.
Old Apr 28, 2008 | 04:01 PM
billmus86's Avatar
My Lips Bigger!
were you splashing in the puddles?
im not sure if it would come up frommundah anyway
Old Apr 28, 2008 | 04:22 PM
if the rear shock mount was loose it could leak, but it sounds more
like it came in from the top.
Old Apr 28, 2008 | 04:26 PM
yeamans17's Avatar
Which dealership are you taking it to? Just curious because I used to work at Jay Wolfe Acura.
Old Apr 28, 2008 | 04:27 PM
mahout's Avatar
You sure windows fully rolled up? Sunroof fully closed? Passenger with very wet feet riding in Fit?
Yah, make sure you fully dry it out before proceding; mold, rot, and rust, not to mention smell can result. Take heart, a cat could have ridden there. customer came in one day ... you don't wanna hear about it.
Old Apr 28, 2008 | 04:30 PM
billmus86's Avatar
My Lips Bigger!
one of the things the fits missing
(from factory)
imma need to get me one thrown in-
sorry off topic kinda
shop vac ftw
Old Apr 28, 2008 | 04:47 PM
veteran13's Avatar
I'm taking it to Jay Wolfe Honda. It's acutally on both sides. I didn't have anyone riding in the back. I don't have a sunroof and the cat doesn't have a key. I don't roll the windows down very often and never leave them down when I park. I wouldn't have noticed it if it wasn't for the stuff on the floor. It looked dry until I pressed on the carpet. Hopefully they will find it.
Old Apr 28, 2008 | 05:24 PM
Mr. Clean's Avatar
My dealer in NC told me that all of the fits they've sold(4) have been brought back for this reason. He said it was the seal inside the door panels. He said the factory didn't press them down all the way and water coming in at the bottom of the windows came inside the car instead of exiting the outside of the door. He said it only happens when it rains for a long period or very hard downpour. He said all you have to do is remove the door panels and push down the seals, then replace the panels. I haven't done it yet so I can't be excact about the procedure. It has rained alot today but I have not checked mine yet. Hope this helps
Old Apr 28, 2008 | 05:30 PM
interesting interesting. does the water end up in the spare area at all?
Old Apr 28, 2008 | 05:32 PM
veteran13's Avatar
I hope it's that. I checked the tire area and no water. It seems the only places that were wet were on the back floor board and damp on the side near the door.
Old Apr 28, 2008 | 05:47 PM
thanks for the info. yah, sounds like they have a fix for it.
Old Apr 28, 2008 | 07:36 PM
Kelmar's Avatar
Frequent FitFreak Poster
For those of us who are visually inclined, when someone does this can they post pictures of exactly which seals are loose?
Old Apr 28, 2008 | 11:07 PM
Mr. Clean's Avatar
Like I said I haven't tried it yet so I don't know exactly what to do yet. I haven't even checked my car yet to see if it is wet. It rained all day today, so I'll check in the morning. if I do it I will post pics. If someone else does it first, please post pics too.
Old Apr 29, 2008 | 06:18 AM
BIBIS's Avatar
Old Apr 29, 2008 | 08:36 AM
veteran13's Avatar
Thanks all!!! I called the dealer with the bulletin number. Hopefully they will find and fix the problem. Will keep you posted.
Old Apr 29, 2008 | 01:48 PM
veteran13's Avatar
Okay, They said they couldn't duplicate the water leak and haven't heard of any service bulletin for the Fit on water leaks. One good bit of good news, I got my dash rattles taken care of. I'll keep an eye on the carpet situation an check it after it rains again. If it does it again, back to the dealer! I'd fix it myself, but if other fit owners are having the same problem, at least there will be some sort of record.
Old May 10, 2008 | 02:10 PM
veteran13's Avatar
UPDATE!!! The Fit went back for the third time with water coming in from the front and rear doors. The dealer finally was able to find the leaks using a powder warer leak detector. It was leakfing from all four doors through the inner seal. They removed and replaced the sealant following the Jazz service bulletin. My sincere thanks to BIBIS and the link to he Jazz problem!!! The dealer said Honda of America is going to release a bulletin for the Fit on the water leaks as well. Of course the actual test will be the next hard rainfalll. FIT FREAKS you're the best!!!!
