Work emotion Cr-kai wheel help
Old Apr 29, 2008 | 03:16 PM
Houston hb's Avatar
Exclamation Work emotion Cr-kai wheel help
Well I was going to order some work wheel cr but I wanted to know on 16" whats a good looking offset to buy, but also is safe. I wouldnt mind being stagger but I dont wanna rub in the front when I turn. This is all going on a black base fit.
here are the pix of the rims
Old Apr 29, 2008 | 03:22 PM
GD3-Fit's Avatar
I <3 SPOON
i ordered mine from evasivemotorsports.com
mine are 16x7 +44 offset and im lowered on eibachs
no rubbing after 6k miles on them so i consider it safe
-Ricky
Old Apr 29, 2008 | 03:28 PM
Houston hb's Avatar
-Ricky
I thought about going with the advan rg 2 too, but I wanted to go with a 16x7 for the front with a 42 offset and a 16x8 in the rear
Old Apr 29, 2008 | 03:38 PM
GD3-Fit's Avatar
I <3 SPOON
16x8 is not necessary for the rear......the Fit isn't RWD so it's not necessary to run a staggered setup. you can use the same wheel size on all 4 wheels
and like most hondas they require high offsets to reduce problems with rubbing.........stock wheel offset is +55 and i'm safe with +44 so if you stay around +45 or higher you won't have any problems unless you want to run a lower offset and use camber bolts and roll your fenders.
-Ricky
Old Apr 29, 2008 | 03:58 PM
NIGHTHAWKSI's Avatar
ive got them in 15x7+44 w/ stock tires, dropped on progress springs. i had my car loaded to the max the other day(4 people, and at least 150lbs of luggage) and wasnt getting any rubbing except for when i hit larger bumps in the road....even then, it wasnt bad enough to really be concerned about.
Old Apr 29, 2008 | 04:30 PM
TOOL's Avatar
Im thinking about getting the Konig knock offs of these. I think they are called Konig Kaitens, hot wheels fashow.
Tyler
Old Apr 29, 2008 | 05:49 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
-Ricky
Correct, but itll look F-wordin sick.
16x7 +45mm offset is the specs on HFP wheels for the Fit.
If you get close to those specs problems should not occur.
+40mm will be ok too, but youll probably rub up front around corners. Thats an easy fix also.
Tyler, I thought those ones were the Mugen wheel reps?
Old Apr 29, 2008 | 06:43 PM
TOOL's Avatar
Konig, Rota Dealer: Buy Low Priced Suspension, Interior, Exterior, Exhaust, Intake Auto Parts: JLB Motorsports, Corona
I think the mugen rips are called MegaRace.
Tyler
Old Apr 29, 2008 | 06:51 PM
Posts in the NUUDE
Blah... Youre right.
Old Apr 29, 2008 | 06:53 PM
TOOL's Avatar
Haha i know my Konigs
Tyler
Old Apr 29, 2008 | 11:31 PM
SD_MR_FIT's Avatar
shit..with a full car i sometimes rub in my rear.
but i have a 17x 7.5.
i had to sand down my rear bumper to make it work though. good luck with the rear.
my buddy is running a silvia offset on his prelude.
but hes running the bigger fronts and smaller rears for traction. turbo h22 heh.
but yeah i would agree with ray.
IT WOULD LOOK SWEET. but on a base fit?
Old Apr 29, 2008 | 11:45 PM
mimpi's Avatar
You wont get that sexy curve look on a 16x8. why bother?
Old Apr 30, 2008 | 09:12 AM
GD3-Fit's Avatar
I <3 SPOON
Exactly....
Old Apr 30, 2008 | 10:34 AM
Houston hb's Avatar
well i have my kenstyle kit coming in and with all my Js racing parts added in it should look pretty good.
Old Apr 30, 2008 | 02:54 PM
SD_MR_FIT's Avatar
oh yes...if your rocking a kit like that,, then forsure!
Old May 2, 2008 | 06:27 PM
2k7gd3's Avatar
please post some pics with the wheels on
I have the same setup, kais on a base nhbp... but w/ tein springs
Old May 3, 2008 | 10:41 AM
Houston hb's Avatar
I ended up going with the advan rg2 gold 16"
Old May 3, 2008 | 02:26 PM
rocklee_110's Avatar
can you post some pics? I've wanted to see what 16 advan rg's look like ever since seeing SD's 17's
billyb
May 15, 2010 01:55 PM
Blueputtputt
Apr 29, 2010 12:55 AM
Chikubi
23
Mar 30, 2009 10:13 AM
mdm427
Jul 30, 2008 12:58 PM
jrose29
Jan 24, 2008 09:35 AM
