Quick, Dumb Question
Old May 8, 2008 | 05:10 PM
Ciggy's Avatar
What size are our rims I want to get new rims but keeps the wheels for now what exact size should I be looking for?
Old May 8, 2008 | 05:12 PM
TOOL's Avatar
15x6. But you can do 15x6.5 and stock tires will fit.
Tyler
Old May 8, 2008 | 05:15 PM
Ciggy's Avatar
damn that small thought they were 16's alright thanks very much. Time to shop
Old May 8, 2008 | 05:16 PM
Ciggy's Avatar
What is the difference between these two and which will work??
15 x 6.5 +40/+45 4h x 100
15 x 6.5 +40/+46 8h x 100
Old May 8, 2008 | 05:28 PM
TOOL's Avatar
You need to make sure the bolt pattern is 4x100! If not they will not fit.
Tyler
Old May 8, 2008 | 05:30 PM
SD_MR_FIT's Avatar
you tell him tool!
by the way if it was a dumb question why bother to ask?
yeah 4x100 lug pattern. try to stay above 35 offset haha
anything above that is fine.
Old May 8, 2008 | 07:18 PM
CorrodesTheFilm's Avatar
Anyone know the offset on the stock wheels?
Old May 8, 2008 | 08:03 PM
Fitftw's Avatar
stock offset should be aruond 40. maybe a little more
Old May 8, 2008 | 08:07 PM
BlackCobra's Avatar
our stock rims are 15x6 195/55/15 with the offset of 55...just bend down and inspect the rims and you will find all the answers you need on the rims themselves.
Old May 8, 2008 | 09:38 PM
mahout's Avatar
Besides 4x100 mm bolt circle for 12x1.5 thread studs on 55 mm offset (down to 45 mm will be fine even when lowered) check the hub bore - the hole in the middle - to be sure it will fit your FIT hubs. Many have failed to check that and get wheels that won't set flat on the hub. Any wheekl width from 6 to 7" should be ok with 195 width tires.
intafocus
Apr 21, 2011 03:16 PM
OJ Glove
Feb 20, 2008 09:50 PM
nexus4400
Apr 2, 2007 10:58 PM
jdmjazz
Feb 17, 2007 03:20 PM
