coolant flush: scale remover?
Old Aug 2, 2005 | 10:10 PM
Abeness
Guest
Posts: n/a
Can ordinary coolant-system scale remover be used in an aluminum engine
during a drain & flush?
jim beam
Guest
Posts: n/a
Re: coolant flush: scale remover?
on a commercial basis? sure. my personal honda? no.
the chemicals in the remover, unless scale is removed to the extent that
all the metal in the system is bright & shiny, are going to be retained
to some extent in any residual scale. that will leave a high ion
content and therefore substantial propensity to corrode. on a
commercial basis, with good testing & ability to absorb failures, it'll
work. for a one-off car, with uncertain status of the system going in,
and uncertain execution of neutralization & flushing processes, i'd
leave it alone. if you're over-heating, service the usual suspects &
consider a new radiator if it's badly scaled.
Old Aug 3, 2005 | 04:34 PM
Abeness
Guest
Posts: n/a
<snip>
Okeedok, jim, thanks for the opinion. I *was* overheating, but only cuz
of a stuck thermostat, apparently. I'll just flush it with water, then.
Old Aug 3, 2005 | 10:34 PM
jim beam
Guest
Posts: n/a
Abeness wrote:
> <snip>
if you can. when you've finshed flushing with water, run some distilled
water through it as well. it's the mineral content of tap water that
causes a lot of cooling system corrosion.
Old Aug 4, 2005 | 09:34 AM
Abeness
Guest
Posts: n/a
jim beam wrote:
>> cuz of a stuck thermostat, apparently. I'll just flush it with water,
>> then.
> if you can.
Have to. No idea what kind of nasty-lloking green stuff is in there now.
Good point. I had planned on simply leaving the few drops remaining
after the flush, but maybe this is a good idea. Certainly not much of a
bother given that the system holds only a gallon, as compared with my
last, a real beast that took some 4 gallons.
Viper143
Sep 14, 2005 08:30 AM
Kent
Sep 10, 2005 05:49 PM
TeGGeR®
Jun 27, 2005 08:22 AM
SadaYama
May 4, 2005 04:44 PM
KWW
May 4, 2005 11:16 AM
