Replacing Timing belt 1986 Honda Accord LX
Old Aug 6, 2005 | 10:01 PM
wpapps@verizon.net
Guest
Posts: n/a
Any information regarding the changing of the timing belt on my 1986
Accord would be appreciated. A link to an instructional web site
would be even better. I have bought the belt, tensioner, water pump
and feel confident I can do the job. My car is a five speed
carbureted engine with 183,000 miles.
Thanks in advance
Bill
Old Aug 6, 2005 | 11:45 PM
Elle
Guest
Posts: n/a
Re: Replacing Timing belt 1986 Honda Accord LX
www.autozone.com has free online repair guides for most Hondas made before
1996 . It's a good start.
I advise first spending a weekend figuring out how you are going to break
free the crankshaft pulley bolt, then doing so. You do not have to fully
dis-assemble everything to get at the bolt. Freeing this bolt is one of the
biggest hoops through which you must jump to accomplish this maintenance.
Old Aug 7, 2005 | 12:31 AM
Bill
Guest
Posts: n/a
wouldn't a half inch air impact tool break free the crankshaft pulley
bolt ???
On Sun, 07 Aug 2005 03:11:17 GMT, "Elle"
Old Aug 7, 2005 | 01:36 AM
SoCalMike
Guest
Posts: n/a
> bolt ???
depends on the tool, how many lb/ft of torque it can put out, the
compressors PSI, hose inner diameter... but yes- a garage compressor
withan ingersoll rand 1/2" drive gun SHOULD be able to.
Old Aug 7, 2005 | 11:38 AM
Elle
Guest
Posts: n/a
Yes, like Mike said.
But there are three other viable alternatives in my mind, based on my
reading here but also based on my replacement of the front crank seal (which
requires removal of the pulley bolt) on my 1991 Civic:
1.
Take it to your local shop and have them break it free with their probably
bigger, industrical size air impact wrench set. Tip I dunno $10. Snug up the
bolt, drive home, and it should come free again easily. Quick, dirty, and
pretty safe.
2.
Or there is a tool that can be purchased for around $50 (maybe less on Ebay
or with enough searching) that will hold the pulley (and so crankshaft
fixed) while you use a breaker bar, 3/4" extension, 3/4"-1/2" adapter, and
1/2" socket to break it free.
3.
Or you can fabricate your own tool. For my 1991 Civic, the cost of this
home-made tool ran about $10.
Email me if you want some more sites (that also have photos) of the whole
procedure, with special attention (of course!) to breaking free the pulley
bolt.
Ask if you want more info about the tools in (2) and (3) above.
> bolt ???
before
the
Old Aug 8, 2005 | 07:30 PM
High
Guest
Posts: n/a
> bolt ???
Maybe this link will help with the bolt:
http://www.tegger.com/hondafaq/faq.html#crankbolt
kamehamehaaa
Jul 22, 2007 01:16 PM
Ray
Aug 10, 2005 08:36 PM
ksrogers
Jul 10, 2005 12:33 PM
Ryan
May 28, 2005 04:41 PM
PK
May 4, 2005 11:16 AM
