Possible fix for rubbing
Old May 18, 2008 | 01:44 PM
Rod2Rice's Avatar
Ground down part of the plastic inside both rear wheelwells. Not sure if you can see in the first pic, but it looked like I could see where it was probably contacting the tire over some bigger bumps. It was only happening infrequently, so I will see how it goes this week and report back.
BEFORE
AFTER
Old May 23, 2008 | 09:40 PM
PipeDiezel's Avatar
rubbing
i have an 08 fit sport. i just put on some OZ 17 by 7 with an bfgoodrich g force tire 205/40ZR17 and when i put like 70 lbs of weight in the back and add three people my well was sitting on my rear tire. WTF and any suggestions?
Old May 23, 2008 | 10:00 PM
Sugarphreak's Avatar
Push My Button
I had the same problem, try a 195/40R17.
4 brands carry this size, Link for more info:
https://www.fitfreak.net/forums/fit-...xperience.html
Old May 23, 2008 | 11:05 PM
Rod2Rice's Avatar
Well grinding that spot down helped, but did not eliminate the problem. Sadly I think I am looking at returning the wheels, and getting something that I dont like as much. Such is life!
Old May 24, 2008 | 12:09 AM
SD_MR_FIT's Avatar
you know what. with my wheels, it was hitting my rear bumper.
so i had to sand paper that beeCH down a bit. now theres absolutely no rubbing what so ever.
Old May 24, 2008 | 01:20 PM
Push My Button
I feel your pain, I returned my first set as well because of the rubbing
My first rims....
Old May 24, 2008 | 01:42 PM
Rod2Rice's Avatar
What size/offset did you have, and what now? I am probably going to end up with a 16x7 42mm offset, what I have now are 16x7 40mm
Old May 26, 2008 | 02:41 PM
MarkyMark's Avatar
Just cut that tab off completely and use a zip tie. I'm running 17x7 +40 with 205/40R17's, no problems anymore.
Old May 26, 2008 | 11:20 PM
Push My Button
17x7 +42mm paired up with 205/40R17, I think the tires had a lot to do with it. Although Illusive was previously running 16x7 +42 and also had rubbing issues.
Old May 31, 2008 | 07:50 PM
07fitsport's Avatar
any more fixes yet for this rubbin?
Old May 31, 2008 | 08:02 PM
Rod2Rice's Avatar
Yeah, well maybe yeah, put different wheels on today. Look at the othter thread haha
Old May 31, 2008 | 09:09 PM
emcss0r's Avatar
Zipties Ftmfw!!
icecreamstpete
Sep 24, 2018 02:03 PM
hogwylde
May 4, 2016 08:02 PM
tanukifit
Hawaii Community
May 13, 2009 11:04 PM
HazelHeart
Apr 22, 2009 10:08 PM
nsx280ps
Feb 5, 2008 07:08 PM
