Question about the JDM Tail Lights
Old May 19, 2008 | 06:01 PM
MNfit's Avatar
Talking Question about the JDM Tail Lights
I just got my JDM LED Tail lights from A&J today and after reading some of the post about them I still have some questions about the install. First the USDM lights have Four plugs: 1 Turn, 1 Reverse and 2 Brake. where as the JDM Lights only have Three Plugs 1 Turn, 1 Reverse and 1 Brake so I was wondering how that works out? MY other question is if I decide to go the route of Extending the wires what should I get for wiring? I have done some wiring before but I always just used what ever wire was laying around, if I extend them I want to do it right so I guess I was wondering what size wire I should pick up? Thanks for any info you guys can give me, I'm excited to get these installed.
Old May 19, 2008 | 10:14 PM
MNfit's Avatar
No one can anwser any of my questions?
Old May 20, 2008 | 12:20 AM
Rod2Rice's Avatar
Cant say for sure, but just common sense tell me that one of the brake lights just doesnt get hooked up, and use wiring at least the same gauge as what is already there. Just dont go smaller, and try and solder it for the best result.
Old May 20, 2008 | 08:08 AM
MNfit's Avatar
Well I kind of figured that one was not used, but I was not sure, I was hoping some one that has installed the JDM lights could chim in and maybe knew what gauge the wire was.
Old May 20, 2008 | 08:11 AM
MNfit's Avatar
Old May 20, 2008 | 08:50 AM
tItAnIuM's Avatar
Hey MNFit, if you get this all figured out and cant find a link to an actual install. Do a write up for the rest of us. I really like the JDM lights and was looking at doing it to my stable of fits one day.
Oh, and it will probably be a 20 gauge wire that you will use. Auto manufacturing wiring usually has a very thin layer of insulation covering it. Don't let that fool you.
Old May 20, 2008 | 11:01 AM
MNfit's Avatar
I got it figured out, I got to run out and get some wires to extend them, Im also working on a DIY ill get up later today.
Old May 20, 2008 | 11:07 AM
fit_love's Avatar
haha i used stereo wire. it worked just fine.
Old May 20, 2008 | 11:40 AM
MNfit's Avatar
yea I have done that in the past to, but its not the right wire to be using
Old May 20, 2008 | 08:39 PM
FitSport2007_5spd's Avatar
You do leave the extra plug empty.
As for extending wires, I read what everyone else was doing and was ready to do that but.....I took a different route for a solution. I opened up the trunk area (wires fed from the driver's side from what I recall) and followed the wires and found that with a bit of pulling and loosening of ties etc, I could extend the stock wires to make it fit. It worked for me but as usual, proceed at your own risk.
Old May 20, 2008 | 09:21 PM
MNfit's Avatar
Thanks, but I already got it all figured out and installed. I went with the extending route with no problems. I originally made the post so I could have a better idea of what I was getting into and have every thing I need before starting the install. In the end every thing went smoothly and I even wrote up a DIY on the install.
BigSpark
Feb 6, 2021 02:48 PM
EXCellR8
Jun 10, 2013 07:49 PM
CAFit
Jun 22, 2009 05:29 AM
aceshigh87
Mar 20, 2008 12:03 AM
towelie
Dec 2, 2007 01:49 PM
