gas tank mistery: 3 gallon missing
Guest
Posts: n/a
Hi, 1997 Civic LX, 5 speed, US model.
The owner's manual says my gas tank has 11.9 US Gal. Each time the
needle reached the EMPTY line, I refilled and usually I put 8.5-9
gallons of gas. This time I wanted to try higher octane (to
troubleshoot a pinging problem) and I decided to run just a little bit
longer before I refill. Usually a gas tank lasts 230 miles, this time I
run 260 miles and I was about to stop to the first gas station, when I
run out of gas on the highway. The momentum kept me going, I was able
to take the first exit and there was a gas station, I bought a plastic
gas can and went back to my car, then I drove to the gas station and
filled up. The total amount of gas it took was 9 gallons, 1 in the
plastic can and 8 more when I drove to the pump.
So, from dry empty to full I put 9 gallons. The manual says I have a
gas tank of 11.9 gallons. Almost 3 gallons of gas are unaccounted for.
WHAT IS GOING ON???
Now I realize how close I came to running our of gas, almost each time,
thinking I have so much gas left in the tank. WRONG. Then, I felt like
a moron, running out of gas, pregnant wife waiting in the car, hot and
humid outside, you figure it out... not fun at all. she wants a divorce
now!!!
To add insult to injury, my experiment also failed: the sound that I
thought was pinging is still there, even though I filled up with 93
octane (usually I get 87). True, I drove only 15 miles since the fill
up, maybe it needs some time to clean the pipes and the fuel injector
of the old gas, or perhaps the engine needs a few more miles to adjust
to the new octane, but still, if the sound remains, I wonder what it
is. If it does not go away with 93 octane, then it is not pinging...
weird. I think this car is haunted. and whatever it is, it lives in the
gas tank, it takes up a volume equal to 3 US gallons, and it makes a
sound similar to pinging. Anyone want to buy this car???
WHAT IS GOING ON???
now!!!
Guest
Posts: n/a
Re: gas tank mistery: 3 gallon missing
In article <1123969593.988861.89750@g47g2000cwa.googlegroups. com>,
> WHAT IS GOING ON???
> now!!!
Did you find out whether or not you have a Knock Sensor on your car? If
not, you need to check the timing. I once owned a car that did not have a
knock sensor and found out if I slighly retarded the timing, that it
solved the pinging problem. I should note that if you retard the timing
too much--your engine will run poorly.
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
> WHAT IS GOING ON???
> now!!!
Guest
Posts: n/a
Your car has to be empty on the side of the road to put in 11.9 US Gal.
"chibitul" <chibitul@sbcglobal.net> wrote in message
news:1123969593.988861.89750@g47g2000cwa.googlegro ups.com...
> WHAT IS GOING ON???
> now!!!
> WHAT IS GOING ON???
> now!!!
Guest
Posts: n/a
I run out of gas. Isn't that "empty" enough? yes, it was on the side of
the road... and teh pump shot of at 9 gallons, not 10, not 11, not 12.
that leaves 3 gallons unacounted for. Unless there is water or
something else in the tank.
thanks
thanks
Guest
Posts: n/a
On 15 Aug 2005 15:35:31 -0700, "chibitul" <chibitul@sbcglobal.net>
>thanks
I agree that this is a problem. While there is such a thing as
unusable gas in the tank, it should not be anywhere near 3 gallons in
a 12 gallon tank. Have you inspected the tank for obvious physical
damage?
>thanks
damage?
Guest
Posts: n/a
Where was the gage's needle after filling? Some pumps like to turn off
way too early, leading to a short fill. Still, three gallons is a lot to
be missing!
> thanks
be missing!
> thanks
Guest
Posts: n/a
the needle was all the way up, actually a hair ABOVE the full line,
like usual. I fill at different gas stations, so this is not an issue.
what scares me is that I came close to running dry so many times, and
the light never came on, and I though I had 3 gallons left in the tank
:) I had not!
:) I had not!
Guest
Posts: n/a
chibitul wrote:
> Oh, one more thing: the low fuel light never came on!!!
Are you sure you even have a low fuel light? My '94 civic does not.
A very modest collection of Honda tech info can be found at:
http://www.geocities.com/ng_randolph
Guest
Posts: n/a
> damage?
Just such a condition came up here a couple of months ago. Fellow found
a huge dent in his tank, as I recall. Check the tank, chitbul.
> damage?
Guest
Posts: n/a
>> damage?
Whoops, make that chibitul. Sorry!
>> damage?
