hey you car audio guys, i have a question about my headunit
Old May 27, 2008 | 03:19 PM
kelsodeez's Avatar
UNBANABLE
if i dont hook up the speed sensor on my headunit, does that completely disable the dvd playback feature? i cant get a dvd to work on my panasonic strada and i think it might be because i didnt hook it up.
Old May 27, 2008 | 04:35 PM
kelsodeez's Avatar
UNBANABLE
does anyone know?
Old May 27, 2008 | 04:40 PM
hondaf1racing's Avatar
you have to ground the ebrake wire or it will disable playback on the main screen unless the ebrake is engaged.
Old May 27, 2008 | 05:29 PM
kelsodeez's Avatar
UNBANABLE
hmm. i connected that one and grounded it. crap. i hope i dont have to take out my headunit. that would be catastrophic
Old May 27, 2008 | 08:38 PM
Rod2Rice's Avatar
Yeah most dvd units have a wire that needs to be hooked to the ebrake, since its illegal to have a dvd playing in the front seat while driving. To get past that, most units you can just ground that wire and all will work. Just be careful!
Old May 27, 2008 | 08:52 PM
kelsodeez's Avatar
UNBANABLE
yea, i am going to take out my headunit soon and do it all over again. sigh, at least ill be able to touch up some spots i missed when painting my dash. but still too much work. ugh.
Old May 27, 2008 | 10:42 PM
Fitting's Avatar
Speed sensor wire is use for the navi portion.
To watch dvd you have to hook a wire to the handbrake which would see ground.
Some unit now require you to pull the handbrake then release and pull it again.
Check your manual to see how your is.
You can wire in a switch if you don't want to hook it to the handbrake or want to watch dvd while moving.
Old May 28, 2008 | 06:01 AM
Injundon's Avatar
Almost all new head units with Navi will shut off a DVD as soon as you exceed you 5MPH anyways. I can't find the manual for your unit though so I can't tell ya. But panasonics to watch DVD's is usually just the e-brake wire needs to be hooked up. As with all things
Reading The Manual always helps
polokid69
15
Oct 27, 2009 01:33 PM
blythe
Aug 25, 2009 07:08 PM
fitster
Oct 22, 2008 08:56 PM
gimme
Sep 13, 2008 05:43 AM
yellowblanket
Sep 5, 2006 09:39 PM
