disabling DVD HU safety feature Pioneer
Old Oct 5, 2009 | 06:42 PM
polokid69's Avatar
First, need to know how to connect green wire from HU to E-brake, next, how do I disable this DVD feature so my passengers can watch while I'm driving ?
Old Oct 5, 2009 | 06:47 PM
Fat Ping Cat's Avatar
https://www.fitfreak.net/forums/fit-...need-help.html
It's not as easy as grounding the parking brake wire like in my car. You need a toggle switch or relay.
You don't connect that green wire to the parking brake at all.
Old Oct 5, 2009 | 07:48 PM
JDMchris.com's Avatar
I run THIS
What unit do you have? theres a few ways to do it.
I have a Fseries and I did the software hack on mine.
Old Oct 5, 2009 | 07:56 PM
polokid69's Avatar
Pioneer AVH P3100
Old Oct 5, 2009 | 08:55 PM
I have a normally closed momentary sw wired up but you can use any SPST rocker or toggle sw and flick it on/off.
Old Oct 5, 2009 | 09:27 PM
polokid69's Avatar
where does the green lockout wire connect to, either direct or switched ?
Old Oct 5, 2009 | 10:02 PM
i don't know exactly what you mean by this
this is one of many different styles of SPST switches. connect the green wire to one terminal and connect another wire to the other terminal then ground it to the chassis (the car... like on a bolt or something).
this is what i have gathered.. someone correct me if i am wrong
Old Oct 5, 2009 | 10:40 PM
green wire needs to go to ground. but you put a switch in series as to simulate the e-brake.
dont watch dvd's while driving. it's already bad enough as it is with people on their
celphones..
Old Oct 6, 2009 | 09:39 AM
polokid69's Avatar
Ok, if I understand you right, connect e-brake wire that comes from the HU to one side of the swicth, then connect a wire from other side of switch to ground like a bolt or something on the car ? Is this correct ?
Old Oct 6, 2009 | 11:33 AM
polokid69's Avatar
Ok, got a swicth installed and works great. Question, does it make a much difference the amps the swicth is rated at ? The one I got was 14amps
Old Oct 6, 2009 | 12:42 PM
14x12= 168watts. i dont think you're going to need any more than 0.5A.
Old Oct 7, 2009 | 05:06 PM
polokid69's Avatar
Thanks. Not knowing everything about amps and voltages, just didn't want blow the car up, lol.
Old Oct 27, 2009 | 09:41 AM
jdmjunkie561's Avatar
Talking
I ended up installing a pioneer avh-p3100 and got the metra dash and wire harness kit , but anyway it has that same safety feature so I have to get a switch too but my question is, is there a specific rating that we have to get ? Like it has a certain amount of amps it can handle according to a certain amount of voltage so is there a range in which we have to choose wisely or anyone will do? I'm not sure if I'm worrying to much on the technical side but all I need is a switch to act like the ebrake so any Info would be great ! I ended up getting a spst switch for an automobile anyway but got a 25 amp for 12v rating so hopefully I should be ok !!
Old Oct 27, 2009 | 10:37 AM
Another ?, do u guys suggest running a in-line fuse for the power wire connecting to the switch? Or is that unecessary ?
Old Oct 27, 2009 | 01:28 PM
25A is more than okay, i think. you dont think that thin green wire's going to carry that much load...it'll become a fuse of its own.
no need for a fuse. i didnt use one.
Old Oct 27, 2009 | 01:33 PM
Talking
U know what I just figured out before u put this post, all it is , is just a ground !! Nothing else , no power is running through it!!! Sorry for the dumb questions !!! Hope I didn't create a confusion !!! But thanks bro for verifying my thought!!!!
grtpumpkin
Oct 5, 2009 06:23 PM
psmo290
Sep 25, 2009 12:02 PM
garseeahh
Feb 28, 2009 02:26 PM
pwnstar
Jan 27, 2009 09:33 AM
gimme
Sep 13, 2008 05:43 AM
