Water sloshing around somewhere
Old May 28, 2008 | 09:52 PM
kinosh's Avatar
I washed the car, including the wheel wells, and now I hear water sloshing around through the air vents when I start up the car, accelerate from a stop and decelerate to a stop.
Any ideas where the water could be? It's NOT the gasoline -- that's another sound altogether.
Old May 28, 2008 | 10:53 PM
kancerr's Avatar
sorry, cant think of anything besides gasoline...unless you had your windows down and water got into your little holder on the sides of the doors?
Old May 29, 2008 | 12:09 AM
cavie187's Avatar
That's odd. tell us if you find it.
Old May 29, 2008 | 06:17 AM
Rob22315's Avatar
The water probably got into the plastic tank-like areas in the duct work. There could be two - one around the A/C evap, and one underneath where the air enters the car from the outside. If there are areas where water could collect, there should also be a drain. Something has clogged a drain.
I don't know the specific layout of the Fit ductwork but I had this happen on an old RX-7. On older A/C systems, dust and mold will clog the drain. Since the car is relatively new, it is more likely a leaf has entered the air duct and clogged a drain where the duct curves into the passenger compartment.
Old May 29, 2008 | 12:38 PM
kinosh's Avatar
It was a loose radiator cap. I lost a bunch of coolant, but not enough to overheat the engine, thank goodness. I topped off the coolant and the sloshing went away. The coolant level must've been at the same level as one of the hoses, because it certainly sounded like water flowing forward through a pipe when decelerating, then back the other way when accelerating.
Old May 29, 2008 | 12:45 PM
George02's Avatar
I think youre hearing the fuel? since we sit on top of our fuel tank, I think if every1 would take some time to listen they would here it. Glad you checked everything tho, a loose radiator cap couldve been deadly to your car
Old May 29, 2008 | 01:02 PM
kinosh's Avatar
It wasn't the fuel. I hear the fuel sloshing too, but this was different. No doubt about it.
Old May 29, 2008 | 01:20 PM
doctordoom's Avatar
Supervillain
nice, glad you found the problem!
Old May 29, 2008 | 01:25 PM
cavie187's Avatar
Oh gosh! At least you fond it before any real damage could occur. Glad it's settled.
correllium
Jun 13, 2013 05:52 PM
jayhawker
Hawaii Community
Aug 30, 2011 04:21 AM
coralaholic
Sep 18, 2009 11:37 PM
Luichenwai
Nov 11, 2008 10:32 AM
Bzzz
Jul 19, 2006 02:11 AM
