Water killed my AC and Radio, HELP!
Old Aug 14, 2005 | 04:55 PM
foopammy
Guest
Posts: n/a
After a lovley projectile well stomach problem by a friend all over my
front car console I decided to hose down the interior of my 200 honda
accord, with the mess she left there was no alterternative, in my haste I
forgot to close the ac vent an I think water got into the front system,
The ac worked for about an hour the next day then the air kept blowing but
all ac/heating air klights went dead and it blows regular (90+ degree in
this heat) air, also the radio, right under the ac worked longer, for
about 3 hours ans then I removed the face to go out to dinner put it back
on, it is also dead. The clock at the top of the console works, I checked
all interior fuses, all are good. I took the console off looked for water
on wires, coroding and so on, all seemed good.... please help, what is
wrong?
foopammy
Guest
Posts: n/a
Re: Water killed my AC and Radio, HELP!
crap of course I meant a 2000 Honda Accord, A/c lights not klights, and
there is a few more typos but hey I am frazzled, other notes all other
eletrical componets fine in car, I have surfed around and seen alot of if
you get your interior wet your eletrical system will short warnings, is
this the situation? if so how do I fix it??? ahhhh!
Old Aug 14, 2005 | 07:34 PM
remco
Guest
Posts: n/a
"foopammy" <foopammy@yahoo.com> wrote in message
news:a1d8272961a83a3290ea8c3890a11a8b@localhost.ta lkaboutautos.com...
> wrong?
Well, first of all teach your friend to roll down the window first. :)
Also, hosing the car down on the inside is not something you want to do, as
you found out the hard way.
There is no one spot you can pin point and say "look there". When a car gets
flooded with water, all bets are off.
All the fuses, including under the hood, are good? If a radio isn't working
at all, it could be due to the radio itself being broken or power to that
radio is missing. AC is a farly complex system in that there are a couple of
components to it. It could be as simple as the AC dash switch, but - again -
it is impossible to say from where we are sitting.
If you are handy with a multimeter and have a schematic to the car, you'll
have to start probing around to see what voltages are missing. If you are
not comfortable doing anything more than checking fuses, you may want to
have a pro look at it.
Remco
tdoom15
Sep 28, 2025 05:15 PM
marcn24
Aug 16, 2015 05:29 AM
Belinda
15
Oct 10, 2014 07:28 AM
scopa
Jul 28, 2011 11:54 PM
7red7
Aug 26, 2008 12:34 PM
