boosting, which gauges to install?
Old May 30, 2008 | 06:20 PM
xorbe's Avatar
I was thinking that just a boost gauge and a wideband O2 gauge would take care of what I need to know that it is working properly. Is there another major gauge I should be thinking about?
I don't really want to mess with installing the gauges, how much might a performance shop charge to install 2 or 3 gauges and a gauge pod?
Old May 30, 2008 | 06:27 PM
cavie187's Avatar
may want to consider a EGT gauge depending on the boost and thermostat. Other good options would be a oil pressure and/or fuel pressure gauge(s).
congrats on the boost.
performance shops are notorious for overcharging for small jobs like that. I would suggest taking it to a buddy that is mechanically inclined and spending an afternoon with him.
Old May 30, 2008 | 06:42 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Boost, wideband, water temp, and maybe oil pressure?
Old May 30, 2008 | 07:41 PM
xorbe's Avatar
I have only pre-ordered the KWSC a/t kit, so I don't have it yet -- but I thought I might get these things wired up and ready.
Like the O2, that takes some welding to install another sensor.
Old May 30, 2008 | 07:43 PM
cavie187's Avatar
Yep. it's a standard bung that you will have to have welded on/in before the cat (in most cases). A muffler shop could do that part for you if you do not have the resources. The rest is hiding wires pretty much.
Old May 30, 2008 | 07:44 PM
kelsodeez's Avatar
UNBANABLE
the gauges i have are boost, oil pressure, water temp and a turbo timer.
Old May 30, 2008 | 07:46 PM
JDMchris.com's Avatar
I run THIS
You DONT NEED any gauges.... If you HAVE to get some I suggestt boost and wideband. Thats all i got.
Old May 30, 2008 | 10:37 PM
xorbe's Avatar
Yeah, I just want "enough feedback" so I can verify things are basically working properly. Like, if I mess up a fitting, I'll see a drop in the boost gauge. Or, if the AFR is out of range, that's a bad one. I don't plan on tracking/racing my car so I don't think I need those other gauges.
So, what's involved in installing the boost gauge, is it simple, or do I have to drill a hole into the metal tubing, or ... ?
Old May 31, 2008 | 02:54 AM
claymore's Avatar
Boost, oil pressure, wideband, coolant temperature, in that order if you need one more Voltmeter.
faxe
Jan 18, 2013 03:25 PM
YeeFit
Nov 1, 2010 09:48 PM
taFITta_sport
May 17, 2010 11:38 PM
YeeFit
Jan 14, 2009 04:16 PM
NotraFit
Dec 26, 2008 09:03 AM
