92 honda civic intermittently not start
Old Aug 23, 2005 | 06:48 PM
Tinob
Guest
Posts: n/a
I have a 92 honda civic. It has a problem of not starting. This only
happens during the summer months. it will start at night when it is not
hot outside. I don't know if the main relay will cause something like
this. If anyone out there has some guidance, i would be most greatful.
Please reply soon, as this problem is driving me crazy.
Old Aug 23, 2005 | 10:36 PM
preludeprob
Guest
Posts: n/a
Re: 92 honda civic intermittently not start
My '86 Prelude did the same thing, the problem was that the fuel pump
was'nt always starting, not getting any current from the relay - it would
only happen when it was hot out. I just ran a hot wire from my battery to
the pump and mounted a small toggle switch in the dash, now if it won't
start I flip the switch and she starts right up. Maybe not the right way
to repair it but it's worked for years ! Matt
Old Aug 23, 2005 | 11:30 PM
TeGGeR®
Guest
Posts: n/a
"Tinob" <weromorena2004@yahoo.com> wrote in
news:e4e02504d5ac21963ade734836375061@localhost.ta lkaboutautos.com:
EFI Main Relay.
http://www.tegger.com/hondafaq/start...html#mainrelay
TeGGeR®
Old Aug 24, 2005 | 04:34 AM
John
Guest
Posts: n/a
It's the main relay. Same car, same problem. Resoldered all points on the
main relay, hasn't failed since.
"Tinob" <weromorena2004@yahoo.com> wrote in message
news:e4e02504d5ac21963ade734836375061@localhost.ta lkaboutautos.com...
Old Aug 24, 2005 | 10:30 PM
Tinob
Guest
Posts: n/a
thanks for all of the information. this is certainly a great site. Again,
thanks
Old Aug 24, 2005 | 11:34 PM
jim beam
Guest
Posts: n/a
that's /so/ dangerous. the main relay is designed to switch off if the
motor is inactive for more than 2 seconds. the way you have it now, you
crash, you flame, you continue pumping high pressure gas into your by
now toasty little engine compartment. how quickly are you going to drag
yourself out of that flaming wreck? what about passengers? fix or
replace the main relay.
Cincfam
Aug 13, 2014 08:16 PM
Rattus The RAT
Sep 25, 2005 09:30 PM
othercarisaminivan
Sep 24, 2005 03:35 PM
Tinob
Aug 25, 2005 11:03 AM
John Smith
Jul 6, 2005 11:06 PM
