Battery light won't go out/Overheating
Old Aug 31, 2005 | 02:32 PM
ParrotQueen
Guest
Posts: n/a
On my 1988 Honda Accord DX the battery light won't go out and I replaced
the battery and alternator. It is also overheating but not regisitering on
the temperature gauge. What else do I need to check before even driving it
again?
Old Aug 31, 2005 | 07:50 PM
'Curly Q. Links'
Guest
Posts: n/a
Re: Battery light won't go out/Overheating
> again?
Fill the rad to the top, and the overflow reservoir to the line MAX. You
may have to bleed some air from the engine block. Don't put any tap
water in your Honda . . It's called Hondacide.
'Curly'
Old Aug 31, 2005 | 10:30 PM
remco
Guest
Posts: n/a
"ParrotQueen" <pupparoo922@yahoo.com> wrote in message
news:0ffda0468d7e430890163dfe09d2032e@localhost.ta lkaboutautos.com...
> again?
Measure the voltage across your battery with the car running. It should be
14.5 volt if the alternator is doing a proper job.
Make sure all connections (grounds to engine, body) are all tight.
Remco
Old Sep 7, 2005 | 10:30 AM
ParrotQueen
Guest
Posts: n/a
Thanks for the info, but I may have killed the old
girl. I did use tap water, along w/coolant, however,
this car has well over 185,000 miles on it. Is it
worth fixing? And what about the battery light that
won't go out even after replacing it and the
alternator?
Thanks,
PQ
Old Sep 9, 2005 | 04:32 AM
Zebra
Guest
Posts: n/a
I would suggest to check the belts, water pump and thermostat.
"remco" <whybcuzREMOVE@THISyahoo.com> ¼¶¼g©ó¶l¥ó·s»D:rutRe.4508$OT1.1395@fe09.lga...
>> on
>> it
>> again?
> Remco
crunchie
Jan 31, 2019 03:31 PM
k3uns
Jun 13, 2012 01:00 PM
noydb
Aug 16, 2005 01:35 PM
disallow
May 6, 2005 11:47 AM
piclistguy@yahoo.com
May 4, 2005 11:16 AM
