AWII Snowflakes
Old Jun 26, 2008 | 01:11 AM
GD3_Wagoon's Avatar
AWII Snowflakes
anybody know the bolt pattern on the 1st gen MR2's?
a friend of mine on mr2oc.com has a set of snowflakes that he wants to get rid of. before i drive out to Valencia, i'd like to know if these will even fit. thanks in advance
Old Jun 26, 2008 | 08:01 AM
mahout's Avatar
I believe the 1988 was 4x100 same as the Fit; however, the offset can be anywhere between 55 and 38 mm so you'll have to check the wheels for the offset cast into the rear of the hub Anything short of 42 mm will rub (and some have said they got 'lite' rubbing at 42.
(the 1991 MR2 had 5x4.5 BC BTW and the stock Fit has 55mm offset)
You will have to check for clearance around the calipers and trailing links and for the hub bore being 64 mm or slightly larger.You will want the backspace to be close to 5" if yopu don't want bearing concerns but it seems that the MR2 wheel was 14x6 or 15x6.
good luck. Let us know what you find. I know a few junkyards I want to peruse.
linnboi
Jul 20, 2012 12:43 AM
Marsbars
Nov 11, 2009 02:29 AM
VBP08GD3
Feb 3, 2009 11:53 AM
bread bucket
Sep 15, 2008 05:15 PM
rvall004
May 20, 2008 04:08 AM
