90 Accord cruise control diagnostic
Old Sep 1, 2005 | 02:30 PM
Frank Boettcher
Guest
Posts: n/a
So the cruise control stopped working on my 90 Accord.
Went through diagnostics on fuse, cruise main switch, both OK
then started through the list on the cruise control module input
harness. Got to the clutch terminal and got a fault (no continuity to
ground). Checked the clutch switch which is the next test in the list
and found that the metal bracket attached to the pedal assembly has a
hole in it where it should make contact with the clutch switch. So it
does not do anything to the switch post when the clutch is pushed or
released.
Looks like some unrecognizable broken plastic pieces on the
floorboard. Is there a plastic component that fills that hole? could
I put a screw and nut in the hole and accomplish the same thing?
Anyone run into this before?
Frank
Old Sep 1, 2005 | 11:32 PM
'Curly Q. Links'
Guest
Posts: n/a
Re: 90 Accord cruise control diagnostic
> released.
> Frank
I've heard this story before. Ask the dealer to fax you the exploded
view of the parts manual. The part is plastic, but if you want to
replace it yourself, maybe a chunk of rubber would do?
'Curly'
Old Sep 2, 2005 | 01:33 AM
Randolph
Guest
Posts: n/a
<snip>
> Could I put a screw and nut in the hole and accomplish the same thing?
Probably, but the replacement part is only a buck or two. Check
http://www.hondaautomotiveparts.com, but they charge shipping + $5
handling, so you are probably better off going to your local dealer.
Old Sep 2, 2005 | 07:33 AM
Frank Boettcher
Guest
Posts: n/a
><snip>
Yeah, I see the part that I need. I'll go to the dealer. Thanks
Frank
Old Sep 2, 2005 | 02:40 PM
SoCalMike
Guest
Posts: n/a
yes, yes, and yes.
Old Sep 3, 2005 | 12:41 AM
Aw
Guest
Posts: n/a
I just had the same thing happen to my 88 Accord LX 5 Spd. Just made repair
a little while ago. I looked up under the dash to find the thickness of the
plastic piece on the brake pedal. Found a bolt with a head close to the same
thickness, put it through the hole in the clutch pedal, installed
lock-washer and a nut...just like brand-new.
"Frank Boettcher" <fboettcher@comcast.net> wrote in message
news:k1heh19slrckikk9i1qphnaatoic3vkojd@4ax.com...
> released.
> Frank
vinnimac
Sep 17, 2016 08:35 AM
allTRACway
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Mar 3, 2016 10:10 PM
Brooksy
Feb 27, 2012 12:25 PM
Minisota Fit
Jan 27, 2007 08:03 PM
Dave
Sep 20, 2005 11:37 PM
