1998 honda accord running problems
Old Sep 7, 2005 | 10:30 PM
mk2supra
Guest
Posts: n/a
i recently put a used motor into my 1998 honda naccord lx 2.3l 4 cyl the
motor was same and went in without major problem. but on startup engine
starts and high idles well then settles at around 750 with a little wobble
but when throttle is applied the engine revs well for about 2 seconds then
stutters to just about stall then back to whatever the throttle is at.
full presure is at factory max readings at the rail. regulator testsn
perfectly also. i have double checked all conections with no luck. any
ideas especially for testing tps or map sesors with out anything more than
a mutli meter also no errors codes are displayed
Edison Carasio
Aug 7, 2008 01:20 AM
sonal83
Jul 27, 2005 09:30 PM
Fijoy George
Jul 24, 2005 11:53 PM
Randy MacKenna
Jul 1, 2005 12:32 AM
MLEGARE
May 4, 2005 11:16 AM
