Powder Coating valve cover? heat resistant?
Old Jul 19, 2008 | 01:35 PM
bluerice's Avatar
i was wondering if anybody knew if i powder coated my valve cover would it reduce the amount of heat that it gives off right now?
Old Jul 19, 2008 | 02:03 PM
redrumm's Avatar
probably not
Old Jul 19, 2008 | 05:57 PM
Fa1's Avatar
Fa1
You can't, it's plastic.
Old Jul 19, 2008 | 07:55 PM
bluerice's Avatar
which valve cover are you looking at cuz the '07 fit valve cover isn't plastic.
Old Jul 19, 2008 | 10:17 PM
Fa1's Avatar
Fa1
I assume you were talking about the intake manifold cover?
Old Jul 19, 2008 | 10:40 PM
solbrothers's Avatar
the valve cover is metal or aluminum. but the engine cover is plastic.
iirc, some fits/jazz's in other countries dont come with an engine cover
Old Jul 19, 2008 | 10:43 PM
bluerice's Avatar
I'm talking about the valve cover which is metal, i assume you were talking about the intake manifold/engine cover which is plastic.
Old Jul 20, 2008 | 03:03 PM
JaySmith's Avatar
Much like previous users have mentioned, powder coat will unfortunately not help reduce the overall heat that is given off by the valve cover. However, if this is something you truly are looking into doing, then I suggest researching high heat exhaust coatings. As not only are they usually offered in a Satin Black, or Charcoal Gray Metallic but will significantly help reduce surface temperatures.
mecevans
Jun 4, 2015 09:26 AM
da9r00d
Mar 16, 2010 09:59 PM
DrKelso
Jun 22, 2009 08:59 AM
AtticusFit
Apr 4, 2008 09:47 PM
Mugen_Dom
Jun 3, 2006 12:44 AM
