Why is Fit EPA stated gas mileage not higher?
At 34 mpg highway, there are quite a few heavier vehicles with larger engines including the Civic that have higher stated highway mileage, why is that? Does that hold true in real life in that a Civic (140 hp engine) will get better highway mileage then the Fit? The Fit does have stated superior city mileage then the Civic. Just curious if there was a reason for that.
I read somewhere that the fit is less aerodynamic than the civic and thus has more drag on freeway.
For one, as stated above the Fit is a lot less aerodynamic than a Civic. Two, the MT version is geared low to make the most of the 1.5L engine. This means high revs at high speed. Three, if people get *better* than the EPA estimate, they'll be happy. If they get less they're going to bitch and moan and complain and want money back, etc.
It's business as usual.
do you both have AT or MT? i'm wondering from the comment about how the MT are geared lower than their AT counterpart.
kepani
kepani
Google the EPA testing for a full description; following the speeds on the graphs may give your eyes a headache.
Few people drive like the EPA tests so don't be alarmed if you don't match the 'official' test results. They are purely to compare one vehicle against another.
For small manual transmission cars its easy to beat the test mpg; for heavy cars its tough to even equal the mpg. One of the interesting things I see on these posts are how much people are using P&G without even knowing.
