Rubbing 205/50/15 +38 offsets
Old Jul 20, 2008 | 04:55 AM
08FitSport's Avatar
I got my Maxxim Airs today 15x6.5 with +38 offsets 205/50/15. I've read this combo will slightly scape the fender to bumper tab above the rear tire and it does. I had to try, well, I guess out comes the dremmel tomorrow.
Old Jul 20, 2008 | 09:42 AM
SD_MR_FIT's Avatar
man i dont know what anyone is talking. i never rubbed with that set up.
im running a different wheels with the exact same set up again and i still dont rub.
but uh...use a die grinder itll help even better heh
Old Jul 20, 2008 | 10:39 AM
Fitcapo's Avatar
... I had 17x7 42mm offset and I rubbe not even dropped you must have done stuff inside your fender or rolled the fenders and did camber stuff to not rub.......
Old Jul 20, 2008 | 11:18 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Just grow a pair peoples.
Old Jul 20, 2008 | 12:57 PM
08FitSport's Avatar
There is a tab that holds the bumper to rear quarter panel that just scraps the outer edge of the tire about 5mm beyond the treads. I went to costco loaded the car with stuff and started rubbing exiting the drive way and on dips on the highway. It is only minor rub but that tab is kind of sharp so it made a small groove.
I think if the treads on the tire is a little more squared on the edge it wouldn't have rubbed.
Ray, I'm not complaining I'm just confirming this combo rubs.
Old Jul 20, 2008 | 12:59 PM
Posts in the NUUDE
Just let it rub away.... Itll stop sometime.
Old Jul 20, 2008 | 08:41 PM
08FitSport's Avatar
In hawaii "bumbai pau". I took it back to the shop they rolled the fender just a tad and "pau" (finished)
SikxChoi
May 16, 2012 04:53 PM
roflmayorga
Jun 4, 2010 04:59 PM
07_g_fit
Apr 19, 2010 10:45 AM
andyd
Mar 13, 2009 10:05 PM
Konad
Jul 8, 2008 09:12 PM
