Satellite in factory radio
Old Jul 20, 2008 | 07:49 AM
djstl_atl's Avatar
Is there a way to install satellite in the factory radio using the aux channel? I want to be able to change the stations using the factory radio. I know you can buy the modulator kits, and the tuner kits made for Honda by Siirus but there is no "official" Honda solution. I dont want to do the mini panel thing, nor do I want to swap out the factory radio. The FM Modulator option has audio issues when you are traveling.
Am I asking for too much?
Thanks!
Old Jul 26, 2008 | 01:03 PM
radareclipse's Avatar
Yes, your asking for too much. Now go to your room.
Since the Sirius/Directed Honda solution doesn't work for the FIT, you are left with an external solution utilizing the aux in. You won't be able to control Sat radio thru the head unit but you will have sound better than the FM mod solution.
Sirius - Honda/Acura SiriusConnect Tuner Interface
ProClip Mounting System *-*Choose Your Country has a great Honda Fit vehicle mount that you could use to hold your Sirius or XM. It's not the end of the world. Good luck!
yellow wolf
Oct 24, 2015 05:51 PM
damoaten
Feb 28, 2013 11:09 AM
IN2TURBOS
Feb 1, 2010 06:32 PM
AXEL
Sep 16, 2008 01:51 PM
Crawly
May 9, 2008 11:17 PM
