where is the horn located 2007 honda fit
Old Aug 4, 2008 | 07:51 PM
smerrick's Avatar
i cant seem to find the horn on my fit i have a 2007 fit does anyone know where the horn is? i am replacing it with to old style ooga horns install below the grille any info would be great
thanx
smerrick
Old Aug 13, 2008 | 12:14 PM
FitVic's Avatar
I dont know if you found the answer but if not then here is the answer. If you remove the front bumper and your looking at it head to head its going by the bottom left splash gaurd. If i had a pic i would post but i dont sorry
Old Aug 13, 2008 | 12:34 PM
caloyski5's Avatar
its under the right headlight. you have to remove the front bumper to access it
Old Aug 13, 2008 | 01:01 PM
Fit_to_be_tied's Avatar
mine is in the center of the steering wheel
Old Aug 13, 2008 | 01:52 PM
sonicsc1's Avatar
can you get to hot wire on the horn without removing anything i want to add sone Hella fog horns thanks
Old Aug 14, 2008 | 09:06 PM
wdb's Avatar
wdb
Yes you can access it for smallish stuff without removing the bumper. Remove the phillips head screw directly in front of the passenger side tire, and there may be one of those plastic buttons too. When you're done you will be able to bend the plastic in front of the tire upwards and access all kinds of stuff like the horn, the fog light, the right hand airbag sensor, and whatever else you might have put there.
Old Sep 7, 2008 | 12:10 AM
Fitn in's Avatar
If you have a sport model, you can just unscrew the passenger side foglight and there it is! Lots of space for a larger horn!
Old Sep 8, 2008 | 11:33 AM
wdb's Avatar
wdb
Heck yeah. I put a pair of Subaru Impreza horns in there with tons of room to spare. It's a cavern.
hohnibria
Nov 13, 2014 10:09 PM
Ursenay
Sep 21, 2012 12:45 PM
TKZ12NO1
Feb 25, 2012 04:45 PM
jofitjo
May 8, 2010 08:42 PM
grablefan
Oct 25, 2009 11:57 AM
