Brake pad renewal
Old Sep 21, 2005 | 09:31 AM
richard
Guest
Posts: n/a
Brake pad renewal
I am renewing the pads in my 1999 accord but cannot get the piston to
retract to enable the new (thicker) pads to fit.
Any idea's what to do?
Thanks Richard
Old Sep 21, 2005 | 03:31 PM
Elle
Guest
Posts: n/a
Re: Brake pad renewal
Either:
- Use a large C-clamp. (The manual says "use a suitable tool.")
- Top off the brake fluid reservoir (to the high mark, that is). Crack open
the bleed valve at the caliper to relieve pressure. Do not let too much
fluid drain. Push the piston in etc. Re-topoff the brake fluid reservoir.
With the second way you run the risk of getting air into the brake system,
and you may have to take some pains to bleed it.
> Thanks Richard
Old Sep 21, 2005 | 05:30 PM
TeGGeR®
Guest
Posts: n/a
"richard" <richard.hycott@ntlworld.com> wrote in
news:l%cYe.11353$ws4.9422@newsfe5-win.ntli.net:
> Thanks Richard
Are these the REAR brakes?
If so, then DO NOT Use a C-clamp! They SCREW in (clockwise)!
http://www.tegger.com/hondafaq/Brakes.html#ScrewIt
If it's the fronts, then yes, a C-clamp as Elle suggests will do just fine.
TeGGeR®
Old Sep 22, 2005 | 08:30 AM
richard
Guest
Posts: n/a
Wicked, thanks to you all I was wondering if they might screw!
Richard
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns96D8AFF288CD0tegger@207.14.113.17...
>> Thanks Richard
> fine.
> TeGGeR®
Old Sep 22, 2005 | 10:30 AM
jim beam
Guest
Posts: n/a
open the bleed nipple too - makes sure all the old contaminated brake
fluid is expelled.
> Richard
>>>Thanks Richard
>>fine.
>>TeGGeR®
Old Sep 24, 2005 | 11:30 AM
tubeguy
Guest
Posts: n/a
I've always used "C" clamps, with small shims when needed. I have used this
method on American made cars, don't know if the Honda pistons are similar
enough, though.
Regards,
Angus
"richard" <richard.hycott@ntlworld.com> wrote in message
news:l%cYe.11353$ws4.9422@newsfe5-win.ntli.net...
> Thanks Richard
phenoyz
Apr 17, 2015 11:18 PM
Yongjin
Apr 17, 2008 03:13 AM
Oct 5, 2005 08:30 AM
venom1055
Aug 16, 2005 10:53 PM
chibitul
Jul 28, 2005 10:30 AM
