17" Wheels for the Fit
Old Aug 6, 2008 | 04:56 PM
Fithonda2008's Avatar
Angry 17" Wheels for the Fit
Hi There,
Does any body know the off set for a 17" for the Honda Fit so it will not rub. I don't plan on lowering the car. The reason why I am asking is because I have the 17" on right now and is rubbing. Thanks
Old Aug 6, 2008 | 05:09 PM
TurboManGT's Avatar
Old Aug 6, 2008 | 05:17 PM
TOOL's Avatar
They work.
There are countless threads on this. Search bar is your friend.
Old Aug 7, 2008 | 02:28 PM
Pacedog's Avatar
Originally Posted by TOOL
They work.
Yes, but in case you don't LIVE here on the forum, it is easier to ask a question unless some smartass like you answers back.
Old Aug 7, 2008 | 02:42 PM
F0NIX's Avatar
What about someone making up a table for diffrent tire sizes (withs), offset and how much the car is lowered. I presume those are the criterias for rubbing or not?
I searched myself and found that thread mentioned above but could not see a clear answer. But I'm hoping my new 17" wheels with 42 inpres and 205/40 tires on my car with stock suspension will work fine. Next question for me is how much can I lower it before I get rubbing issue?
A nice table or diagram here would be nice.
Old Aug 7, 2008 | 02:45 PM
mahout's Avatar
Originally Posted by Fithonda2008
Hi There,
17x7 with 42 minimum offset if you don't lower and 45 if you do. Try to get as light a wheel as you can afford. Ditto 205/40x17 tires.
Old Aug 7, 2008 | 03:13 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
hahahahahaha
that was hilarious
pacedog sure showed tyler what's up
haha
yeah a "graph" or something would be awesome though
Old Aug 7, 2008 | 03:16 PM
gimme's Avatar
Master FitFreaker
No offence, but you dont have to "live" on here to know about a search button. Most all forums have them.
It's just these threads get repetative is all.
Old Aug 7, 2008 | 07:15 PM
holloway2006's Avatar
I have 17x7 wheels +40 offset and they only rub over large bumps or smaller bumps if I have 2 other people in the car.
Old Aug 8, 2008 | 12:34 PM
Hey Holloway, what size tires did you put on those 17?
Mine is 205/40/17 and not lowered. Going throught and intersection on 20mph and it rub. What's your take onr that? Any feed back would be good. Thanks
Old Aug 8, 2008 | 01:56 PM
Those are the same size tires as I have. The rubbing will happen and as long as it's not bad, when your tires wear down they will rub less. Also, some tires have kind of a square sidewall on them that makes the tire a little wider which may rub some. I'm not real sure how to describe the tires better without pictures, but I hope that was a good enough description.
Old Aug 8, 2008 | 11:08 PM
radareclipse's Avatar
Leave it to mahout to get the question answered. Life is too short to start searching. Quick and easy. NEXT!
Mooser1454
Sep 2, 2018 04:29 PM
Ninkumpoop
Oct 1, 2011 05:27 AM
ElectricD
Dec 5, 2010 08:08 PM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
braziers
Nov 10, 2008 11:10 AM
